SOURCE: coolant type
That bike came from the factory with regular green antifreeze/coolant mixed 50/50 with distilled water. You can get it pretty much anywhere that sells automotive products.
The only way it should be anything other than that would be if someone has changed it over, which is rare.
SOURCE: I have a 1982 V45 HONDA SABRE VF750S motorcycle.
I had the same problem with mine last year. I put a new tire on it and had it balanced. The vibration went away. I would at least have your tire balanced.
Ben
SOURCE: how to change sparkplugs on honda shadow motorcycle
VT1100 has two spark plugs per cylinder, the sparkplug caps are snap-ons so they're fairly easy to remove. You need a spark plug socket wrench to remove and replace the spark plugs.
SOURCE: how do you change the oil on a 2007 Honda sabre
you can down load one here for free,it takes a while to load,lots of bikes.
http://www.carlsalter.com/motorcycle-manuals.asp
SOURCE: 2004 Honda VT 1100 C2 Shadow Sabre that has gone
Check the out put of your regulator/rectifier, though rare with honda r/r's since they are made very well and rarely break down ( at least the older model ones ) it could be what is causing this unless you have a short circuit in your wiring harness.
Testimonial: "Thanks for the help "
