My turn table is getting power, but nothing is being displayed on the track selection screen. I know its not the ribbon seeing how I switched the ribbon out with one that worked to figure out it it had a short. Also the 1.6 fuse isn't blown either seeing how I switch that part out also. So any idea's of which part I would need to replace to get my cdj up and running again?
SOURCE: CDJ 800 Has no power
this guy don't know what he is talking about,the cdj800 does have a fuse,if you open the unit up just make sure it's unpluged,if the fuse is blown replace it with one of the same rating,it's right next to the switch inside the unit,it's very easy to take apart just 5 screws,I have one that won't power on also but it's not the fuse,but yours could be,just check it out and don't be afraid just be careful when handling electronics so that you don't send static charges into the chips.
SOURCE: pioneer cdj 800 problem
More than likely you have a damaged CD transport, or needs to be calibrated or professionally cleaned. I would suggest taking it to a service center.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
SOURCE: replacing cdj cue buttons
Not hard at all. Just have to open her up. I would suggest purchasing the service manual, which has instructions on doing this and useful for other repairs, as well as parts list, and parts diagrams.
Pioneer CDJ800MK2 Service Manual
- OPTiC
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
SOURCE: Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
SOURCE: Pioneer CDJ-800 Vinyl Mode Broken
Same thing here too. The Vinyl mode stops the player and when I press it out of Vinyl mode, it works fine. What is causing this problem? I took it apart and cleaned the insides, which were gross, I think someone spilled something on it. :-(
Still, I cleaned the track and put it together and still it doesn't work? Might be time to take it to the shop.
