When cold, the right half of the screen has lines in it, and that half is stretched vertically, showing two images of that half. The left half is normal.
You have a board connected on the side and another on top.. the board controls your horisontal lines and your side board controls your vertical.. Afte using the television for some time the board gets very hot and the solder gets damaged. You get what is called cold solder preventing the electrical current to pass. You need to retouch with solder but do it carefully. its best if you know some one with soldering experience. That will solve your problem. you can get more details at www.bestdirectorysolutions.com
The stretching on the right half is actually taking place throughout the picture, but is nearly invisible on the left side, then becomes more visible as you move to the right. There is a "normal" image, with a second, stretched image below it. The stretched image is not inverted and appears to be twice the height of the "good" image. The set comes out of this after half an hour or so of running.
