Computers & Internet Logo
Posted on Oct 30, 2008
HP Tower (2000 Media Edition)
I don't know the exact model (not @ home). Powered down yesterday before I left for work. Ten hours later, pushed the "tower" button and NOTHING happened. I am miserable w/o my comp at home. Checked all the connections to no avail. I am computer illiterate. Can anyone suggest something that I can try? It was FINE yesterday morning and then BOOM, it is dead.
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Oct 31, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
3517
Points
13
Sounds like your power supply unit is dead. Do you get any power or hard drive lights on the unit? If not, I'm afraid it's a repair shop problem.
Sorry to be the bearer of bad news!
My hp rp5000 beeps twice when i start it and no picture to my acer lcd monitor.
You most likely have a faulty graphics card. There are many things that you can do to try and diagnose this issue on your own, but it may be wise to ask for the help of a local computer expert who can determine the exact issue and inform you on how to proceed.
Golf 2000 is my car Recently I changed my Waterpump, TB and FCM. I find my AC sometimes works good, but other time just blow warm (compressor doesn;t comes on). Yesterday after adding two cans of...
firstly i think you have overcharged the Ac system as the most it should hold is 650 grms for this system on this model ,if too much gas it will click in and out and slow the engine down ,as for the gauge readings then renew the sensor its on the housing at the front in the plastic housing ,depending on year and model this is where most are ,but some later models have a sensor at the back of the head left side from front
3helpful
It is a 2007 Jeep Commander rocky mountain edition... My husband drove it to do some errands and then came home. About 45minutes to an hour later we went to leave again and it wouldn't start giving us a...
We have the same exact problem!! been happening the past year (about 5 times). Finally went all the way out friday, wasnt able to start after 2 hours, left work and went back sat and finally started after an hour. got it home and it wont start again. Why isn't there a FN recall on this problem that so many LOYAL JEEP OWNERS are having?!?!?!?
I'm having display issues on hp slimline s3120n w/Vista. When the PC boots up, the monitor momentarily lights up, then goes into standby mode. I attempted resetting the BIOS following the steps on HPs...
its ok just POST TO HP PC or HP Desktop, with tag data.
for sure fixya does not have all 10,000 HP PC's listed nor will it ever.
H3LL even HP dont. (shock)
a desktop PC, (easy to fix , them all) no magic and ATX spec.
standards in play.
why not do the tests in the correct order.?
and do not put other HDD os in to your box, or the reverse.
that will not work.
first off the screen is black.
so you go in to BIOS, does it work and stay working there.??
that is first no the HDD, we play with OS later.
make the screen work first
see that VGA jack on rear of PC
try a different screen see if you can get to BIOS and hold there for say 5minutes, or more?
if that fails ?
this is an Emachine, with no video card, (or was added later,did you look>)
all Emachines, if you add at Video card, you must turn off the on MOBO GPU chip 6150LE
or it will get very confused. (which to use)
only you know if rear side, has x2 ,15pin VGA ports on the rear
if only one there, then its lock box stock, ORIGIONAL.
it only has 1 PCI-express 16x slot for added VGAG card.
if present remove it, and use the normal JACK
the goal is to get one of the 2 VGA jacks to work
that take owning 2 monitors, lacking a second, barrow one.
BIOS work now?
http://support.hp.com/doc-images/234/c00910084.jpg
BIOS hot keys (F1, F9,f10, esc, delete key)
the book on your machine tells you which hot keys work on your PC. and must be known by you or diagnosis goes to hair pulling.
http://jeepdied.com/look/puters/dead-screen.html
not yours but will look same with your exact model
try to know there are many sub models on all HP systems.
1helpful
I want to know that "is how many Windows XP version is publish So far"? any one answer detail i know only 2 one is HOME edition and 2nd is Professional " IS it ???? what about Media Center Edition...
to your amasement one answer is 8 versions
Windows XP Starter Edition
This edition is aimed for first-time desktop PC users in developing countries. This edition can only run three applications at once.
Windows XP Home Edition
A version of Windows XP for home users. This edition replaced Windows 9x/ME
Windows XP Home Edition N
This is a special edition of Windows XP Home Edition for the european market
without media player
Windows XP Professional
A version of Windows XP for both businesses and home users. This edition replaced Windows 2000 Professional
Windows XP Professional N
This is a special edition of Windows XP Professional for the european market without media player
Windows XP Media Center Edition
A Windows XP version for Media Center PCs with an easy to use interface and remote control support
Windows XP Tablet PC Edition
This is a Windows XP version for Tablet PCs with pen and speech capabilities
Windows XP Professional x86 Edition
This edition is for AMD64/EMT64 64-bit processors
guess you didn't knew that.
nice question and thanks for using fixya.
Please vote if satisfied.
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
2answers
Bad experience with HP customer support, please read ?
It sounds like they are out sourcing beyond the USA Borders.....
System logging off as soon as i starts it. Please see details..
Looks like you've tried a lot. Try this stuff.
1) Try F11 instead.
2) Dunno. Corruption?
3) chkdsk /f
4) Microsoft EULAs are much less crackable than their software, according to BitTorrent.
2answers
Restoring windows xp home edition
HI satisfier
provided his disk has a newer build version than your this should be no problem if his is older then you will receive the mssage that "a newer version already exists"
Grand Canyon Tech
Grand Canyon Tech
