Chevrolet 1999 Chevy Silverado Logo
Gene Nelson Posted on Mar 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1999 silverado gauges intermittent
Gauges turn on and off, Dash lights go on and off.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 241 Answers
  • Posted on Mar 01, 2012
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
241
Questions
0
Helped
110506
Points
760
Check the battery connection. it may loosen due to engine vibration.
Every thing works no gauges working
None of my gauges will work, but my turn signal indicators ...
www.americanautowire.com/.../none-of-my-gauges-will-work-but-my-tu...
None of my gauges will work, but my turn signal indicators, high beam ... As we've discussed previously, anything electrical needs a 12 volt feed and ground to work. ... 09/28/2015 There are a number of new products coming in Nov/Dec this ...
my gauges quit working - CarGurus
www.cargurus.com > Questions > Ford > F-250 Super Duty
CarGurusSep 21, 2013 - my gauges quit working - My odometer, speedometer, fuel, tach, trip, and ... I tried fixing the wire and had the same problem....so I replaced the shift lever and everything is back to ... no gauges will work in dashboard 1 answer.
No dash gauges, but dash lights - Car Forums and Automotive Chat ...
www.automotiveforums.com > ... > Dodge > Caravan ' Voyager
Feb 6, 2010 - The dash lights work fine, so does everything else. The dash gaugesjust don't work. This is something that has been an intermittent problem ...
All my gauges quit on my 2003 silverado the dash lights still work but none of the gauges move
Hi, this is a pretty common problem on these Silverado instrument clusters. We can definitely help you out with that. Click here to learn more about these Silverado instrument cluster problems: Dr Speedometer Instrument Cluster Repair Speedometer Repair Guage...
2003 chevy silverado gauges dont work any of them dash lights do just the gauges dont
Hi, this is a pretty common problem on these Silverado instrument clusters. We can repair it for you or provide you with the parts to do it yourself. Click here to learn more about these Silverado instrument cluster problems: Dr Speedometer Instrument Cluster Repair Speedometer Repair Guage...
1999 silverado gauge lights do not work
You probably already checked this but the simplest solution is the control used to turn on the interior lights and to dim your dash lights. It is a dimmer switch to the right of your headlight switch. If it is turned all the way down then you would have no dash lights and no headlight chime. Turned all the way up it turns on your interior lights. If this isn't your issue and if no fuses are blown then try to turn the dimmer switch all the way up with your headlights on. If the dash lights come on with the interior lights then your switch is fried and you may have a short in the interior light circuit.
5helpful
Half of the dash lights are out on my 2003 silverado
My brothers got an 03 Silverado had problems with some gauges, turns out they had a factory recall on the entire gauge cluster. He took it in they replaced the whole thing free and no more issues.
Dash gauges and Information center work intermittantly - All fuses are in good
is it the lights of the gauges dont light up or the gauges dont work period? if they dont light up then check the bulbs that are behind the gauge cluster and they could be burnt out i have the flickering prob with my ac hvac controls and half the lights on my gauges dont light up due to bulbs being burnt out i just havent spent the money to get some blue leds to put in there
1helpful
All the dash lights come on and off intermittently 1999 sunfire
no its not the pcm. its the the instrument panel, it in itself is a computer. sounds like a plug may be loose or a loose ground wire
1helpful
2answers
Where is the fuse location for instrument cluster on my 04 GMC Sierra?
Here you go. Under hood fuse block
Ign. Fuse E
and
ipc/dic
both fuses are 10 amp
I hope this helps. Take care.
1999 Venture - Intermittently dash gauges (idiot lights) come on.
CHECK THE ALTERNATOR OUT PUT USING A DIGITAL VOLT METER.IT SHOULD BE 13.5 TO 14.5 VOLTS.IF NOT REMOVE IT HAVE IT CHECKED AT ADVANCE AUTO OR AUTO ZONE.THEY WILL CHECK IT FREE.DUE TO LOCK OUT FEATURES.BESURE TO TURN OFF RADIO.BEFORE REMOVING THE NEGATIVE BATTERY CABLE.SO YOU WONT LOSE RADIO CODE TO PLAY RADIO.
Top Chevrolet Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
