Our question is vague. If you must replace the exterior handle only, Point 7 in Prakash's excellent answer is enough.
Tip: to repair a broken exterior handle: fill both sides of the broken handle with metal reinforced epoxy like KwikWeld, then push nails (heads clipped off, 4 or 5 cm long, 1.5 or 2 mm diameter) into the small part (over half the length of the nails will stick out), then put the handle back together and wait. The nails will reinforce the epoxy and you'll have several cm of metal totally filling up the handle where it is broken.
Hyundai Repair Manual
https://www.reliable-store.com/search?type=product&q=Hyundai+sonata
Download it
For exterior door, just pull the black plug on side of door. Unscrew the bolt and dont let if fall inside. Now old door handle will come out. Now take a piece of string and pull the lever inside where the handle is and put new handle in its place and pull string out of way. Screw that bolt back in. I did this on every door on my car. No need to take the entire door apart.
SOURCE: how to replace a door handle on a 2006 hyundai
Step1:
First, unscrew the 7 screws holding on the door panel
Step2:
Next you carefully pry off the tweeter cover that is where the mirror is.Lift the panel up and off of the door . Undo all of the wiring connections except for the window controller.
Step3:
Open the 2 black rubber view ports (Circled in Yellow) and roll the window up or down until you see the 10mm bolts that hold the window in place.
Step4:
Loosen, but don’t remove these bolts. Slide the window up, and tape it up, or remove the window and set aside. Next, unplug the door lock plug and move the door panel out of the way.Unscrew the gold 10mm bolts that hold on the metal inner door panel . Also remove the Phillips screw that holds the inner door handle on
Step5:
Unscrew the small bolt that holds on the lock cylinder that is behind the quarter-sized black cap on the side of the door. Be careful with that little bolt or it will fall into never land .Pull the lock cylinder out and set aside.
Step6:
Now grasp the door handle, and with your free hand smack your hand holding the handle towards the back of the car. This will release the door handle.Under the door handle is a Phillips screw. Loosen this screw a few turns but don’t remove.
Step7:
Now undo the 3 black star shaped screws on the door lock.You can now wiggle the inside of the door handle until it comes free. See the tabs that hold it onto the door . When you go to put it back on be sure the tabs get back in the right place.Pull the whole inner door panel and lock mechanism free by wiggling it out of where it sits.
Step8:
Now you can undo the 3 cables; 1 from the outer door handle yellow mechanism, 1 from the inner door handle mechanism, and 1 from the inner door lock lever.Put on the new lock and put it all back together.
Be sure to test it as you go. I had to turn the lock cable to the inner door lock lever 180 degrees because it was not unlocking properly when I put it back together the first time.
A couple of other notes, there are 2 pieces of plastic that are for the robots to use when putting the door together for the first time. one is a 3 pronged white plastic thing riveted to the inside of the metal door panel. The other is a white plastic thing covering the lock mechanism. You can cut off the fingers and throw the plastic cover away they are both
useless and in the way.When you put it all back together, just go in the opposite order of disassembly. It is a little tricky to get the yellow plastic outer door handle holder into place. Be sure that the little tabs grab the metal of the door or things will not fit together properly.Be sure to test the power window after you put the window back in place. Do not overtighten the bolts on the window, it is glass…..
SOURCE: both door handles broken on 94 Hyundai sonota
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
SOURCE: Can't program hyundai sonata to open garage door
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
HOPE THIS HELPS
SOURCE: I need to replace the
Welcome to FIxYa.com Image -1 Rear Door COMPONENTS REMOVAL AND INSTALLATION Image-2 1 Remove clip using a piece of cloth (Manual type only).Then
the door window regulator handle. Image-3 2. Remove the rear door inside handle housing. Image-4 3. Remove the mounting screws (3EA) from the rear door trim
panel. Image-5 4. Insert a trim panel remover between the trim fasteners
and the door trim panel to pry off. Disconnect the connector. Image -6 5. Remove the door pull handle mounting bracket and door
inside handle. Image 7 6. Remove the door trim seal. Image-8 7. Down the door glass and remove the door glass run and
delta lower channel. Tightening torque Rear door glass mounting bolts: 0.8- 1.2 kg.m (5.8- 8.7
Lb.ft) Delta lower channel mounting bolts: 0.8- 1.2 kg.m (5.8-8.7
lb.ft) Image-9 S. Remove the carrier plate mounting bolts from the door
regulator channel and remove the door glass. Image-10 9. Remove the door regulator channel mounting bolts and then
remove the door regulator assembly. Tightening torque Door regulator channel mounting bolts: 0.4 -0.6 kg.m (23 -
4.4 lb.ft) Image-11 10. Loosen the door lock actuator mounting bolts and remove
the latch assembly. Image-12 11. Remove the door outside handle mounting bolts. Image -13 12. Remove the waistline molding. 13. Installation is the reverse of removal. When installing the door trim seal, butyl tape should not be
placed over door trim fastener mounting area. images coming up next Thank you for using FixYa.com Regards, Lee Davidian
