It turned out to be a phone line difficulty, not the modem. Seems there is a not so friendly mouse in my house. Thanks anyway. Live long and prosper.....
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
? You don't need a driver for the modem unless you have it hooked up via usb. If you are using USB go get a PCI nic card and install it. That's an easy way around needing a driver
401 Authorization Required is the message you get after the default allowed password attempts have failed. When trying to access the Speedstream, you didn't type in the correct password which results in that failure message.
* You dont need any special drivers to install modem. * Open up internet explorer, type 192.168.0.1 in the address bar and press enter key. * Now you should see the configuration page of modem. * On the left side, click on Advanced button, below that, you will see "connection configuration" option - click on it.
*** If it asks for modem access code anywhere, you can find the code underneath the modem. please type it ***
* Under this page, you have to enter the email address in username field and password, change the connection type to smart keep alive, click on save changes
* Now it may ask you for restart modem. click on restart. within 1 min, you will be connected to internet.
The password is unique to the modem. How to get the modem on line to read it?
