I have removed all screws from top of machine, including the one in the coffee bean bowl. No covers are budging!
SOURCE: Lots of disturbing noises, no coffee
It is is easy, if you know how to do it... as always
First take of the wather, trach bin etc,
Start with removing the cup wher the beans is stored, the adjustment knob for the mill is a tricky part. Remove it by bending out the side of the knob. Thereafter remove the screws from cup and those you on see on the top.
The front (silver frame) is removed by lifting it upwards, behind it you have 4 screws that has to be removed.
The last two screws is found under the wather tank.
Now you should had take away 11 screws, at least...
Bend the back of top and it will be off. Finally push the rest of the plastic cover backwards.
Do you know what the error codes says? I have know 6,8and no coffy...
SOURCE: Krups Orchestro Dialog coffee machine
that mean no coffee go through us if you dont use the machine often you might have coffee residue on the grinder teet remove the coffee bean in the hole were the coffee bean goes use a brush and clean the grinder teet very good with the residue of coffee gonna grind and gonna go through thanks for usig fixya pierre
SOURCE: Krups XP9000 fully auto unit will no longer grind
Perserverance...it's cheaper.
Also found a limit switch which i think is thermal so once removed the grinder is operational again!
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
SOURCE: I have a 12 month
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
