I replaced the control panel on my dishwasher last Thursday... It worked great for a few cycles. I went to run it tonight and it won't start (but all lights work on the control panel)... I don't understand! What could it be???
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
SOURCE: Diswasher control panel not working.
Micro controller to be checked. Refer user guide and contact the service provider.
SOURCE: Kitchenaid dishwasher....clean light will not
Hi
If clean light is blinking indicates an issue with heater circuit, door switch or wash pump. To resolve this please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
SOURCE: KitchenAid Dishwasher won't drain KUDI01ILBL6
Do you have an air gap on your sink? Check it to see if its plugged.
