Not running...check filter light on
Hello. #1-Use a vacuum cleaner with hose attached and vac the drum vent screen inside the drum. #2-disconnect AC power(unplug or switch off 220volt breaker) carefully remove hose from air duck of dryer and vac inside of dryer. Vac the hose and exhaust port. Reattach hose, reconnect AC power and test operation. #3-Problem still present the exhaust sensor or the (most likely) the exhaust fan not working properly. Good Luck!
Testimonial: "Thank you Gene P. I will try that."
