I need to replace the filter and ordered a new one, but now I can't get the screw top off. It just turns and turns. Is there some secret to getting it unstuck or am I just sol? Thanks!
Sit on the top, and pull on the handle very hard. It will pop off, and most likely not break.
Then you will need to take the nut off with some pliers, and glue it back into place.
Most likely some water got into your filter at some point, and it rusted. Making it nearly impossible to screw out. So when you turn the top it spins the nut instead of screwing out. Mostly due to the circular type nut that Honeywell poorly chose.
