Question about ECHO, Inc. Shred n Vac
Need new bag.
Does bag have velcro easy connect collar? Cost?
Could you please advise me how much it would cost for a replacement bag for a Shred'n' Vac model ES2100.
Monica Hargrove
Posted on Nov 21, 2008
6ya staff
SOURCE:
How do I put a new bag in my vacuum cleaner
The collar on the replacement paper bag has to be forced onto the outlet as described and illustrated in the replacement instructions printed on the bag.
Jan 19, 2015 | Vacuums
The upright connector pipe wont stay connected after being taken apart to clear clog
You need to make sure that the rubber "O" ring is under the collar. You also need to make sure that you tighten it fully, there are three "bumps" that you need to make sure that you tighten the collar to.
Apr 19, 2014 | Oreck XL2200 Bagged Upright Vacuum
In need the instructions
This is a seat post mounted bag, with attachments for the rails (2) on the bottom of the seatpost.
1. The straps going over the top of the bag will have to come apart. Removing them from the loop they pass through before re-attaching with the velcro.
2. Undo the straps and then feed them over the metal seat rails.
3. Re-assemble the straps in the same manner they were before and loosely attach the velcro. You will later tighten up the tension on these straps to snug the bag up under the seat.
4. Attach the velcro strap on the posterior of the bag to the seatpost.
5. Now the bag should be supported by the seat post strap and the seat rail straps (2). Hanging loosely and oddly from the seat area.
6. Tighten/snug the straps from step three, so the bag is drawn up against the bottom of the seat. Try adjusting all the straps on the bag until the bag appears to sit well under the seat.
7. DONE
Jan 05, 2013 | Avenir Bigmouth Seat Bag
How to remove cat hair from Velcro?
In order to clean the Velcrobetween washes you need to use a sticky roller to remove the cat hair.You'll be surprise to see howefficient sticky roller is and that no hair will stay on your cat Velcro.
Jul 18, 2012 | Cats
How do you attach the bag to the barracuda 2595 blower
The motor housing has a spring loaded, hinged cover over the fan blades (so you don't chop your fingers off when using it as a blower). Open the cover using a screwdriver or narrow tool. Holding the cover open, attach the vacuum tube. Attach the collection bag to the discharge port (same place you attach the blower tubes) and secure in place using the velcro strip sewn onto the bag. Adjust the ******** the bag to fit your shoulder, turn power on and go. To empty the bag, just unzip the bag completely. Make sure you tighten the velcro strip so the bag doesn't come off while you are sucking up leaves.
Oct 11, 2011 | RTO Weed Eater Electric Barracuda 2595...
I purchased a Polaris 3900 on 6/2/2010 and have already replaced two filter bags. Both times the bag has become wedged between the chasis and the wheels tearing the bags. Any suggestions?
First, make sure that the velcro closure on your pool cleaners bag is sealed tightly. If the velcro is coming lose, it could be the problem. Next, make sure that your wheels are operating at the proper RPM. Too little RPM could cause the pool cleaner to be sluggish and not create the proper tension to keep the bag floating. It should be between 30 and 36. If it is running at less than 30 RPM, there are few things that you can do to fix it. If an adjustable valve is installed on the cleaner line, open it completely so water can flow freely to the cleaner. Check the filter screen in the in-line filter
for debris that restricts water flow and clean if necessary. Also clean the skimmer, filter, and pump baskets. Check the hoses, connections and swivels for leaks that cause loss of water pressure. Finally, if none of these solutions work, remove the blue restrictor disk from the UFW.
Jul 02, 2010 | Polaris 3900 Sport Pool Cleaner ()
How do I attach the vacuum bag and get it to work
There should be an air intake grille of some type, the bag should have a round opening that fits over a collar around the air intake, it may be held in place by a Velcro strap.
You don't give much detail to go on.
May 25, 2010 | RTO Weed Eater Electric Barracuda 2595...
I have an oreck upright cleeaner I have not used for a while where I put bag on is the attachment 2 part because bag will not stay on.
you should have a velcro bag holder slide the bag opening onto the velcro bag housing after it is folded down then with the bag in place swivle the bag housing to the velcro and it should snug up to the inlet tube where all of the debris is vacuumed into , let me know if this helps?? thanks The Vacuum Doctor Don Alb,NM
Nov 19, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Kirby G4 Vacuum "BOOT"?
Greetings from GoVacuum,
The bottom part of the bag, which you referred to as a "Boot" is actually called a Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S. The part is only available to purchase with the fill tube assembly, this is the part that the disposable paper bag connects to inside the cloth outer bag.
Kirby has redesigned this fill tube, as the original design sometimes would cause the inner fill tube to crack. The Mini Em-Tor Fill Tube Assembly, part 199493S comes already assembled with the "boot" at the bottom, and the vacuum bag collar (the part the bag actually attaches to) at the top of it. You will need to remove the cloth outer bag from your old part, and put it onto the new "Boot". The cloth bag connects the "boot" with a special zip tie, which is Kirby Vacuum Bag Clamp. Kirby Part # 196599S. Where it is possible to remove the bag clamp without breaking it, I will warn you that this is no easy task. Spare yourself the aggravation of having to try and remove the clamp, and just cut the bag clamp with a knife or scissors.
You will also have to remove the top of the bag collar at the top of the cloth bag by releasing the fill tube from the inside of the cloth bag.
All of the parts are located on our website, www.govacuum.com. If you have any questions about the repair, you can get me on a live help, chat service located in the top right corner of our website. I'd be happy to walk you through this.
Thanks,
Chris Jones
GoVacuum.com
Sep 30, 2008 | Kirby G4 Bagged Upright Vacuum
Vaccum Bag
Slide the plastic piece off the cloth bag and open the top. Looking down into the cloth bag, you will see the old bag. It is secured to the machine near the top. You will find the cardboard collar about a third of the way down. Remove it carefull. Now, stand BEHIND the machine and put your knee against the back of the handle and taking the new bag, open the hole in the cardboard collar and insert the bag into the cloth bag and put the cardboard collar onto the handle fitting. It helps to put the lower part of the hole on first and then press the top of the collar onto the handle fitting. The idea of standing behind with your knee against the handle is so that as you attach the bag, you will be pushing against your knee which will steady the machine and allow you to use the required force to complete the action. Once completed, fold the top of the paper bag down, so that when you replace the top slider, the paper bag is NOT clamped between the cloth bag and the slider.
Jan 25, 2008 | Hoover Soft Light U4266-940 Bagged Upright...
ECHO, Inc. Shred n Vac Logo
186 people viewed this question
Top Echo Garden Experts
Mike
Nick Olsen
choprboz5
Are you an Echo Garden Expert? Answer questions, earn points and help others
