I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
SOURCE: Omnitech Wireless Weather Station model
Push and hold down the channel button, wait for beep, then on the sensor, push and hold the tx button, wait for beep.
SOURCE: My weather station by Lacross will not display the
http://www.lacrossetechnology.com/9611/manual.pdf
If that's not the right manual,you can use the link below, and select the model..If the model is not there, that means the manual is not available...
http://www.lacrossetechnology.com/support/manuals.php
Take care
SOURCE: the sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
