After a few years, our Sony Bravia suddenly will make a loud crackle/scratching noise, the volume gets LOUD for a second and then returns to normal. Sound is run thru an amp, extra speakers and we have digital cable tv.
SOURCE: clicking noise sony bravia kdl-40v3000
It is most likely the cabinet setteling as it is cooling off. Nothing uncommon with all the plastic that is used in TV's.
SOURCE: crackling noise from tv
That crackling noise has nothing to do with the television and everything to do with your antenna. It is merely signal breakdown, when you get signal interference with analogue tv you get snow, with digital you get little squares on the screen and/or sound breaking and cutting in and out, get a licensed antenna repairer to come out check your signal strength as you may need a booster or your antenna could just be a few degrees off....
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
SOURCE: Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
SOURCE: Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
