Question about LG LMVM2277ST Microwave Oven
Touch pad Certain features on the touch pad are not responsive.
    New Friend:
    Problem Solver:
  • 13 Answers
Microwaves are really not cost efficient to repair. It's cheaper to buy a new one. Sears has comparable to your model starting at $70, walmart $60. :)
Posted on Feb 27, 2012
6ya staff
SOURCE:
Only certain buttons of microwave oven touch pad work.
Hi, welcome to Fixya!
From your question, I suspect the fault is from the control board of the microwave. This is why some buttons on the the touch-pad are not working.
Have the control board replaced and the buttons that refuse to work will start working again.
I hope the above is clear. If not, please let me know.
Regards.
Nov 17, 2011 | Microwave Ovens
Touch screen is lighted. No response to touch.
The touch pads are a common fault on microwave ovens they go out for a variety of reasons but mostly due to moisture getting inside the pad. These can be replaced pretty reasonable and are not that hard to do. You can google your make and model and find a touch pad or get one from your local parts supplier. Whn you replace it make sure you never use any liquid or spray on the front of the oven, it will slip through the cracks and ruin things. You might also take the unit aprt and look for a fuse, some models have them and others don't. If there is one it will be inside the door next to the touch pad.
Jul 02, 2011 | GE JVM2070 Microwave Oven
Touch pad is loose at the top. The upper choices don't respond to touch. The bottom choices will respond. How do you reattach the pad?
I would think that the touch pad will need replacing.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 09, 2010 | KitchenAid KHHS179LSS Convection /...
The screen seems locked with no response to any touch pad 'key' I switched it off at the wall but now its just asking me to press the 'clock' key but no response. Before that it seemed to work at some...
Two possibilities...the controller has failed -- buy new microwave!
Second possibility...many microwaves have a child lock feature. Open the door up and read the labels stuck around the door frame of the cooking cabinet. If yours has this "child lock" feature, it will tell you how to unlock it.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Microwave Ovens
Manual for breville microwave bre799gmsse
this feature allows you to program your oven to begin cooking automatically at a designated time of day. Simply touch Custom Help pad. Touch the number 3. Enter the start time. Touch Clock pad. Enter cooking program. Touch Start/Touch On pad.
Jul 26, 2009 | Microwave Ovens
The ''stop/clear'' and ''clock'' setting feature quit working. Everything else is fine.
This is either a defective touch pad membrane or the entire main control board is not functioning correctly. many times, the unit will have a separate touch control but, most newer models will have the touch pad integrated together with the main assembly. In this case, replace the main touch control assembly.
Jun 09, 2009 | Emerson Microwave Ovens
Kenmore micowave
IF IT IS THE KEYPAD THAT IS LOCKED, ONE OF THE TOUCH PADS SHOULD BE HELD FOR 5 SECONDS TO UNLOCK THE
TOUCH CONTROL.YOUR INSRTUCTION MANUAL WILL TELL
YOU WHICH PAD TO HOLD. IF NOT AVAILABLE, TRY EACH PAD, ONE AT A TIME. HOLD EACH PAD FOR 5 SECONDS.
IF NO RESPONSE, TRY THE NEXT ONE. WHEN YOU FIND THE ONE THAT UNLOCKS THE CONTROL, WRITE IT DOWN
FOR FUTURE REFERENCE. THAT PAD WILL ALSO LOCK THE CONTROL WHEN HELD FOR 5 SECONDS.
Mar 28, 2008 | Microwave Ovens
Control panel on a whirlpool microwave
SOME ELECTRONIC CONTROLS HAVE A LOCKOUT FEATURE THAT IS ENGAGED AND DISENGEGED BY HOLDING A CERTAIN BUTTON FOR 5 SECONDS. LOOK FOR A LOCK PAD AND HOLD IT FOR 5 SECONDS TILL IT BEEPS.
IF NOT AVAILABLE, THE TOUCH PAD MAY BE UNPLUGGED FROM THE MAIN P.C. BOARD OR MAY BE DEFECTIVE.
ALSO, TRY UNPLUGGING THE MICROWAVE FOR 5 MINUTES
TO RESET THE MICROCOMPUTER, THEN PLUG IT BACK IN AND SEE IF IT WORKS.
AN ELECTRICAL OUTLET NOT WIRED WITH PROPER POLARITY OR NOT GROUNDED CAN AFFECT ELECTRONIC APPLIANCES ALSO.
Mar 26, 2008 | Whirlpool MH7140XF Microwave Oven
LG LMVM2277ST Microwave Oven Logo
150 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
