Question about KitchenAid KGRA806PSS Gas Kitchen Range
Oven won't shut off
  • Kristen Denison
    Kristen Denison Feb 27, 2012
    is the control panel functioning at all?  And is it being used with natural gas or propane?
  • Gracie Masterson
    Gracie Masterson Feb 27, 2012
    It is a natural gas range. everything works! oven starts up but the shut off/ off button won't work.
    New Friend:
    Problem Solver:
  • 13 Answers
It sounds like the control panel has a short in it for the off button. I did some research on that particular model and it seems that this is a common problem along with the whole panel going out. I did a quick search to see if there was any recalls on that model and didn't find any but I would suggest that you look into it futher. I am including a web page that has some consumer reviews that you should read. http://www.epinions.com/review/pr-KitchenAid_KGRA806PSS_Kitchen_Range/content_431610302084 Hope this helps you but frankly my suggestion would be to try and get a different model this one seems to be plauged with problems and will probaly cost you more money in repairs and piece of mind then you want.
Posted on Feb 27, 2012
  • Kristen Denison
    It sounds like the control panel has a short in it for the off button. I did some research on that particular model and it seems that this is a common problem along with the whole panel going out. I did a quick search to see if there was any recalls on that model and didn't find any but I would suggest that you look into it futher. I am including a web page that has some consumer reviews that you should read. http://www.epinions.com/review/pr-Kitche... Hope this helps you but frankly my suggestion would be to try and get a different model this one seems to be plauged with problems and will probaly cost you more money in repairs and piece of mind then you want.
6ya staff
SOURCE:
Self clean won't shut off
try taking the plug out and put it back in
Nov 23, 2012 | GE JTP90 Electric Oven
Turntable and light won't shut off.
The common cause is one or more bad door switches, or possibily the keypad control board.
Apr 16, 2012 | Emerson Black Microwave Oven
The turntable and light won't shut off when not in use
The door switch, one or more are a common problem, or the keypad control board, "less likely"
Apr 16, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
Advantium won't shut off
The problem is the microprocessor control board, professional should verify.
Mar 11, 2012 | GE Advantium 120 Convection/Microwave Oven
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
Oven won't shut off
Here is a tip that I wrote about why an electric oven will not shut off.
Electric Oven Problem Oven will not shut off
heatman101
Sep 28, 2011 | Amana AOCS3040 Electric Single Oven
Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
Aug 02, 2011 | Jenn-Air Ovens
Stove reads F3 and won't cancel and oven won't shut off?
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Frigidaire Ovens
KitchenAid KGRA806PSS Gas Kitchen Range Logo
87 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
