Hello, my washer stops in the middle of the cycle and doesn't drain the water. The display shows: Ld, or another time Fl. Do you know what it means? I appreciate your help My Kenmore ELITE HE3t is stuck. The rinse cycle stoped and the time remaining flashes. No change upon trying to cancel and restart...just changes the time remaining. The rinse/spin status light is on and the flashing time remiaing will not go off. My HE3t front load started having problems clothes being wet when removing them and needed more spin cycle. NOW I have this related problem. What to do next?
My kenmore elite finish washing my clothes, but when i open the door the washer didnt rinse and drain the water. i try to put it to rinse and drain again, but continue with the same problem...
the washer beeps when the clothe its done but when i open the door didnt rinse and drain the water all the water still there.
Sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
cycle won't cancel or start
