Hi
By volume do you mean Ring tone volume or Handset volume?
Ring tone volume adjustments.
Press menu >settings >phone profiles
Scroll the phone profile you ares using.
Press on options >edit and select call alert volume.
Scroll right or left to adjust the volume levels.
press on select and then save.
The handset volume adjust is done by pressing on the 1st side key in idle mode.
SOURCE: is there a unlock volume code to increase the
I don't think so...
It's a key pad problem..
Your keypad buttons are connected to your volume control at the side of your phone.
So check if the key pad is still connected to the volume control system..
SOURCE: how to increase volume in samsung E250
The "secret code" for audio options is *#8999*8378# but before you use this you should know that when i tried to do so,my earpiece is now so low,that i can not even hear what the other person is saying.Use the code only if you know how to do so!
SOURCE: my samsung star gt-s5233s model mobile volume low
How can I change the message tone for samsung GT-s5233s
SOURCE: What is the secret code
Ih this site you can get all mobile codes http://www.wickedunlock.com/ - Wicked Unlock
