E-Machines eMachines T3830 PC Desktop Logo
Anonymous Posted on Feb 26, 2012
I cant get into safe mode on emachines t3642
Emachine is stuck in a loop started with not reading any cd but would play dvd. Tried to fix it and got stuck in a loop saying BOOTMGR missing.
  • Anonymous Mar 28, 2012
    I Fixed it. Had to change out the cd/dvd rom and put the repair cd in it.
3 Related Answers
Anonymous
  • 98 Answers
  • Posted on Jun 15, 2009
SOURCE: my dvd wont play any dvds emachine t5212
check to see if the little video wire is hooked up inside to the dvd player.
rocket9244
Rick Moore
  • 66 Answers
  • Posted on Oct 23, 2009
SOURCE: how to install memory for T3642 eMachine
eMachines T3642 Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 1.0 GB = 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T3642 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 1.0 GB = 512 MB (removable) + 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
INSTALLATION PROCEDURE
1. Place the computer power switch in the "off " position and disconnect the AC power cord.
2. Remove the computer top cover following the instructions in the model-specific owner manual.
3. Before touching any electronic components, make sure you first touch an unpainted, grounded metal object to discharge any static electricity stored on your clothing or body.
4. Locate the memory expansion sockets on the computer motherboard. If all the sockets are full, remove smaller capacity modules to allow room for higher capacity modules.
5. The ejector tabs shown in the illustration are used to remove a module. By pushing outward on the ejector tabs, the module will pop-up from the socket and it can then be removed.
6. Handle your new module carefully; do not flex or bend the module. Always grasp the module by its edges.
7. For most installations, DDR modules can be installed in any available expansion slot. Other installations may require the memory to be installed in a particular sequence based on the modules capacity. Check your owner manual to determine the correct installation sequence for your configuration.
  • Insert the module into an available expansion socket. Note how the module is keyed to the socket. This ensures the module can be plugged into the socket one way only. Firmly press the module into position, making certain the module is completely seated in the socket. The ejector tabs at each end of the socket will automatically snap into the locked position. Repeat this procedure for any additional modules you are installing. install_ddr.gif 8. Once the module or modules have been installed, the computer top cover can be reinstalled.
    9. Plug in the AC power cord and reinstall any cables disconnected during the installation process.
    10. Turn on the computer and follow the instructions in your computer owner manual that describe the steps necessary to allow your computer to recognize the newly installed memory.
  • I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
    Fabio
    • 400 Answers
    • Posted on Nov 02, 2009
    SOURCE: My Emachine T5010 reboots on Windows loading screen.
    Before windows loads press F8 on the keyboard to get an advanced menu.
    choose the option that says disable automatic restart on error and see what error you get.
    Also try the Safe Mode option.
    That click sounds like the harddrive is failing.
    Emachines cannot acces to safe mode stuck on windows/welcome screen and dont have a recovery disk
    Remove ALL media, DVD,CD,USB, Unplug, remove battery, plug in , reboot, OR, unplug while it's on and repeat if necessary. Use this procedure to do a System Restore/Recovery: http://answers.yahoo.com/question/index?qid=20060819000752AAUeYvu It would be helpful if you posted the eMachine Model and the OS you are using.
    tip
    How to Recover eMachines Notebook Windows Password
    eMachines, as a brand-name laptop, is attractive to many netbooks users. We also call it as Acer eMachines for its developing history. We often receive letters from eMachine notebooks users on Acer eMachines password reset for forgotten eMachine administrator password. How to remove eMachines password or change eMachine password if I forgot Windows 7, XP, Vista password? Now, begin discuss the ways to unlock eMachine password.
    1. Reset eMachines administrator password with other admin account
    This means that we still can login our computer by accounts with administrative rights or privileges. Please never forget the default administrator, it may help much!
    eMachines XP password reset from Safe Mode
    A. Switch on eMachine Windows XP laptop and keep pressing F8.
    B. Opt for "Safe Mode" and press "Enter" key at the Advanced Boot Option windows.
    C. At login screen, choose the Administrator account and keep "Password" column blank (or input the changed password if the default Administrator account password has been changed before).
    D. Start - Control Panel - User Accounts - select the account needed to change password - Change the password.
    E. Input a new password, confirm the password again and then complete
    Acer eMachine password removal on XP.
    eMachines password recovery on Windows 7
    We can recover forgotten password with built-in admin account:
    A. Power on Acer eMachine computer and press the key: F8.
    B. At the Windows - Advanced Boot Options, select "Safe Mode with Command Prompt" and press Enter to confirm. Then PC starts Windows.
    C. Choose the Administrator account shown on the account screen, and then login windows - Administrator: cmd.exe. Input command: net user Lily abcd and Enter to confirm (Lily is the account needed to break password; abcd is the new password for the account).
    D. After command finished, we can restart eMachine Win 7 laptop and login with account - Lily, password - abcd.
    2. Break eMachines password with only guest account
    We know that the guest account can not do more operations on a security PC. So, we have to refer to other way to retrieve the admin account for further operations.
    Bypass eMachines password with recovery disks created before lost eMachine password
    When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
    Retrieve eMachine Windows password by DIY a password reset disk after forgotten
    It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
    We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
    A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
    B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
    C. Reset the new eMachines password.
    Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
    Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
    Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
    1helpful
    MY EMACHINE DESKTOP RECOVERY CD DOENT WORK
    Hello
    When booting up pc have you held the delete key or f2 key down to bring up the boot menu?Should be a option of cd dvd or hdd to boot first.
    You want the cd dvd boot option on top or first.tThen reboot pc.
    When asked hit any key to boot from cd, hit a key.Should start install.
    If youve done this, clean the dvd or cd install disc with some windex and a paper towell,try again.
    You can also do a system restore from control panel recovery option.
    Emachine reboot problem
    First of all remove ant cd from drive when booting up uinless you are using a bootable windows disk. if the problem still persist when then computer starts booting up keep pressing f8 until you get the choice to go in to safe mode. Once in safe mode choose the option when prompted go to system restore points and restore the computer to a date availabe wich is before the date of the problems.
    My cp will not boot up at all. the light turns on but nothing comes up.is there away to fix this? i did try starting in safe mode which is f8 (i hope) it ask to start in safe mode,safe mode with...
    You go to Bios mode and choose the frist boost is DVD/CD then save new setting and turn off your comp. Insert Win XP operation disk and see if it could fix the problem.
    Wont load passed windows xp screen
    Try holding down the "F-8" key when the emachines logo appears, see if you get a prompt for "safe mode". If you can get the system up and running in safe mode, shut it back down from the start menu. That should rewrite the boot sector and may clear the problem.
    Why is emachine stuck in running on safe mode?
    What OS are you running, xp or vista?? You may be able to recover your computer using the recovery console and associated commands. Just insert your windows cd and press r when prompted.
    Let me kno
    EMachine laptop/windows xp problem
    ur window had been crashed pls install new window
    Emachine loop again
    Try first of all 'Last good configuration'
    If still no go consider what it is you have done latly in termso of installing new software or a new hardware device.
    Remove the most recent.
    Finally in Safe Mode go to Start/Programs/Accessories/System Tools/System Restore and reset the machine to a time before the problem started.
    Top E-Machines Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Andrew Chrostek
    Andrew Chrostek
    Level 1 Expert
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
