SOURCE: how do you install a
lean washer back remove dust cover remove c clip holding pulley on ..good luck getting back together ..c clip can be difficult due to lack of clearance ..be sure you put bottom washer back on
SOURCE: Replacing maytag thrust bearing kit 12002213
yes you can do it yourself no special tools are need just a couple good flathead screwdrivers and a lot of patiance be sure to put all the new washers and bearing back on in the same order the old ones came off putting the C clip on can be a little tricky but take you time and it can be done you may hvw to use the flat head to pry on the trans. shaft to get the clip in the groove then use a pair of chanell locks or pliers to snap it on if you get a new style bearing it may not look like the one you take off and not have all he washers just snap the small plastic pice onto the bearing put it on the the pulley the most of the time just the thin washe then the C clip the dust cover put belt back on the test machine
SOURCE: drum seems to be off its bearings
http://www.pcappliancerepair.com/whirlpool-dryer.php#books This site has parts, manuals, and the pictures you see when you put in your model number will give you a quick peek into the unit.
