On of the plate it say it is single phase; 220 volts; the wires that come out of the motor are green; black; white.There is nt a plate cover that expose the wires. Can I just use a 110 plug to plug into a 110 outlet
There should be a label showing the change, one wire gets switched over to a different screw, all motors are different, but all basically the same, some will not switch. It would be just as easy to run a new line to your motor and it will be right, single circuit, 220 volt,?amp, no worries., Your motor as is will not run in 110 volt mode at all. Hope this helps.
