SOURCE: Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
SOURCE: using a refilled ink cartridge on a Lexmark x4850
Yes, most Lexmark cartridges as well as many other manufactures use something called 'Smart' Chips in the bottom of the ink cartridge. Usually unplugging your (about 10 seconds) printer resets the memory in the printer. Hope this helps!
SOURCE: lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
SOURCE: how to reset lexmark36 ink cartridge
try to reset ur printer
press and hold on power button for about 20 sec then press hte power button again
