I have a maxell dvd+Rdl disc 8.5 gig and the unit can't read it. I need to load onto my Dell 8600 laptop
SOURCE: cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
SOURCE: Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
SOURCE: hi sir,can i ask to where is the video output of Sony CRX320EE CD-RW/DVD-ROM Combo Drive
sasae ds daea
SOURCE: driver for sony cd-rw crx830e
Go here -----------> http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=RC956904&l=en&s=hied&os=WW1&osl=en&SystemID=INSPIRON1300/B130&catid=-1&impid=-1
It's a dell website. Dell also uses the same CD-ROM on there laptops. Scroll down to where it says CD/DVD and choose Sony. Good Luck!
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
