I have an amplifier AMC 3050a with a problem in one of the speaker output (Channel L), when the increase in the volume of the amplifier output voltage increases greatly with regard to the other exit that is stable, it makes the speaker cone bass seem to be leaving but in the other this does not happen, it works correctly
You can't control it with the balance control?
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
SOURCE: My amc 3050a over heats then the fuse blows, this
this may be due to the fault that the output is overheating and exceeding the currrent limit set on the fuse . Hence the fuse is blowing off. If the amp is working normal after it coold off and after replacement of the fuse, then the overloading of the output needs to be checked.check the rating of the speakers. Do not use the amp inside a closed cabinet. If possible use a good ventillation , a fan and try out if the amp works fine. If so check if the soruce is producing any distortions to thermally run the outputs. reduce volume level , and check the heating. once you have located the problem of the heat proceed to isolate the section. helpful? Good day
