Question about Zebra Symbol MC3190G Handheld Mobile Computer
Motorola MC3190 can not get ip address from dhcp on wep wi-fi
Terminal connects to the wifi network but is not realy connected, can not get ip address. wifi uses wep encryption. Please help. wireless log: 15:39:36 Log Initialized 15:39:37 Renewing IP address. 15:39:45 Unbinding adapter. 15:40:14 Binding adapter. 15:40:14 Disabling IPv6. 15:40:15 Regulatory table uploaded to radio. 15:40:16 Disabling 802.11d. 15:40:16 Setting country code to: US 15:40:17 Using profile: salon 15:40:17 Setting SSID: salon 15:40:18 Associated to 00:24:f7:be:9c:70 15:40:18 Authentication not required. 15:40:18 Connected to network. 15:40:34 Renewing IP address.
    New Friend:
To configure the terminal TSD on Windows Windows do the following:
1. at the bottom of the panel find the network icon (it can be crossed with a red cross or be a red exclamation mark)
2. click on it with the stylus and select Options Options
3. In the window, select the menu and set the following values:
OP Mode Filtering - leaving only a tick AP Networks, and remove Ad-Hoc Networks
Regulatory - select the country (you can USA) and remove the checkbox Enable 802.11d
Band Selection - I chose only 2.4 GHz Band, 5 GHz mark removed
System Options - all ticks left (Profile Roaming, Enable IPv4 Mgmt and Auto Time Config)
Auto PAC Settings - AllowProvision ing AllowRefreshin g and both set as No
IPv6 - Enable IPv6 checkbox removed
Change Password - leave blank
Export - click the button Export Options, a window to save, note that saving should be in the folder \ Application and contain letters and symbols with the extension. Reg
After that, push the Save button and
Posted on Dec 14, 2012
    New Friend:
Marcos Mendes and Andre Andrade at Nixcomm, Recife, Brazil
Our problem was solved just right now, first of all, be sure to active the Radio, you need to click in Wireless companion on the main menu, and after that click at wireless launcher, and ENABLE RADIO. Done, you can Find LANS, when you find a lan and try to connect with this and have some problem with Profiles, you just have to acess Wireless companion again, and wireless launcher again, this time select Options and then take the drop down menu bar till you get Regulatory, so uncheck the box 802.11d and everything's gonna be alright, enjoy! Hope you got that!
Posted on Aug 02, 2012
4 Suggested Answers
6ya staff
SOURCE:
thesuperdude
Oscar Suarez
  • 97 Answers
SOURCE: Can't connect wifi
do the following:
click on the mobile companion icon on the menu bar at the bottom. this is the radio icon.
click on options and from the drop down menu, select regulatory. uncheck the box 802.11d and select the country where you are.
save the options.
from the drop down menu again, select the last option called export and click on the export options button. save the default registry file and you are now sorted.
Posted on Jun 15, 2009
thesuperdude
Oscar Suarez
  • 97 Answers
SOURCE: INTERNET CONNECTION
You will also need to go to settings>connections>advanced and ensure that on the two drop down menus you have either my network or my isp and ont one of each.
Posted on Mar 26, 2009
shaheenshm
Hi im having problme in RF Scanner motorola ,while searching for wireles connection msg prompting for scann error " Adaptor not available " I did all the solution replace required dll file and reboot,cold boot,so far no solution....
Posted on Jun 14, 2010
Tv says check internet connection,done that still not connected
K Spare . Check network settings on TV . ip address
How does Tv get ip address?
. Do you have a DHCP server on your router ?
If yes then set the network setting on TV to obtain IP address Automatically.
If WI FI being used on TV then set up Encryption WEP or WPA encryption Key as well.
Jul 07, 2016 | Computers & Internet
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
My connection keep failing my password is correct.they are asking for my ip address where do i find that,
dont give anyone your ip adress,contact your internet provider to fix problem,if you are using someone elses wifi you will have that problem,use your own
Apr 26, 2015 | Amazon Fire TV Stick
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
Jan 27, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
"obtaining IP address"
May I suggest to temporarily have no wep/wpa set at all, go for open and see if that works for the tablet.
If not, try changing the SSID of your wireless network.
Also, there may be insufficient IP's in the DHCP pool.
Or, maybe a MAC filter is set.
Nov 09, 2013 | Samsung N8020 Galaxy Note 10.1 16GB WiFi...
Toshiba laptop. I asked about this wifi prob a couple of months ago. i thought I solved the prob but I now got another laptop(acer) and I have no problems with connections. Do u think it is a driver...
I don't think it's the driver is the culprit. Sometimes that could be, but in most cases, the problem is with the settings/setups, please check the Wifi Properties. Most Wifi cards automatically detect the network and connect to the network available, but there are still many networks which require manual setups. Before you proceed to the steps below, please make sure that Dhcp is already activated on the wifi card properties of you system, otherwise you'll need to supply an ip address. The basic steps are as follows; Find out what are the Ssid, Channel, Mode and Wep keys. Some Wi-Fi locations do not require a Wep key. Many Wi-Fi providers have this information on their Web site or they'll give you the information when you purchase access. Ensure you have a firewall program installed and running. This will protect your data. Start up your laptop and look for the Wi-Fi network icon in the bottom right of the screen. Click on the Wi-Fi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab. Now you can check whether this helps or not. If you have set up these things correctly and still not having fixed it, then you need to reinstall the drivers and again setup the wifi settings. Good luck. Thanks for using FixYa.
Jun 08, 2010 | Computers & Internet
CANNOT CONNECT TO WI-FI
First turn on the wifi in laptop then make sure your wifi network adapter tcp ip property that it get ip from router.
Aslo make sure router settings are perfect.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Jun 02, 2010 | Computers & Internet
WIFI
connect to wifi using my blackberry curve 8520 1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
Mar 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
Zebra Symbol MC3190G Handheld Mobile Computer Logo
8,899 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
