TV TURNS ITSELF BACK ON AFTER BEING TURNED OFF
The most common thing is malfunction in your remote control. Try moving the remote control to another closed room, and see if it still does it. If it does... well, I know how to setup a TV to turn itself off after a period of time you set, but how to turn it on? no.
Also something, might be stupid, but I'd tell it anyways, is that someone is fooling you by ór using the remote control, ór having another remote control, and turning it on all the time.
And another thing. By "off", do you mean standby? or actually turned off by pressing the button? Because this is only if it is turned off with the remote control. If it is explicitly turned off by the button, then it might be a malfunction on your tv, meaning you could call the support of the company that makes these tv's, and if it is actually a malfunction, you could get a new tv for free, if your warranty hasn't outdated yet.
That's all I can think of, I hope it helps.
I have the same problem.the thing is that I got my deck from a friend without the remote so I´ve been having problems with the pink wire too.But I didn´t know you could bypass it with the remote. how do you do that is there a code? And if there is what is it?
and how do you program the code for it to work.I´ll try to get a remote as asap.
I have the same problem with the pink wire. I didn´t know you could bypass it. could somebody give me the code and tell me how this works.how do you program it?
