Still power on as top oven works fine.
I suspect that you did cut power to the oven when you replaced the element. therefore the oven needs to be reset as new. there are quite a few pages of instructions on setting the timer so be prepared if you are going to to proceed with this "little" project.
I was able to locate your manual online here:http://kitchen.manualsonline.com/manuals/mfg/zanussi/zuq_875.html?idRes=625295
I suggest unplugging it for a few minutes...then plugging it back in. Hopefully if the electrical is good you will see the oven's timer flashing. then you can proceed with the instructions from page 7.
Otherwise, you may have a blown a short and should get a licensed electrician to look at it.
Another option would be to contact the manufacturer:[email protected]
Or, find the bloke that installed it and invite him over for dinner and maybe he'll notice it's not working and will fix it for free! ;-)
Good luck mate!
SOURCE: ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
SOURCE: main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
SOURCE: Zanussi ZDQ 595 fan oven not heating
You need to replace the round fan oven element located at the rear of the oven compartment behind a removeable cover where the fan is located.
Testimonial: "Thankyou - i did not know there was another element in there!! I cannot believe how expensive these ovens are considering the simplicity of their construction and low cost of the components inside.. Thanks again..!"
SOURCE: The bottom oven on my Zanussi ZUQ875 keeps
Does it trip the breaker when you turn the light on only? Or when is the breaker tripping?
SOURCE: I have a ZDF20X double oven and the main bottom
Most likely it is a faulty oven heating element.
You will need to replace the element.
Usually the element is a circular shape which is situated near the fan, normally you will need to remove the back of the oven, Switch off the power at the wall first, locate the element and remove the fixing screws and electrical connections then fit the new element and reconnect.
Only attempt this replacement if you are confident to do so and have a basic electrical and mechanical knowledge.
Thanks for help so far. Just to make clear i have no display/power on the digital display so i cannot reset this. There is still mains power as the top oven still works. Is there a fuse or thermal overload on here somewhere?
Thanks
