The monitor reads input signal out of range change to 1600 x 900 running windows 7
Hello
Boot the computer into SAFE MODE. Go to CONTROL PANEL - DISPLAY PROPERTIES. Change the screen resolution to a common size - like 800x600 or 1024*768 and save the settings. Reboot the computer.
Everything on the screen will be very large but you should be able to see the desktop and make additional changes. Go to CONTROL PANEL and DISPLAY PROPERTIES again, and change the screen resolution and click APPLY. This will change the resolution to the new settings and will give you the opportunity to revert back to the old setting if it does not work.
Once you hit APPLY - the screen will change. If you can see the screen, you will see the option to ACCEPT the changes or to REVERT back to the prior setting. If you do not choose anything, the system will revert to the prior setting automatically - typically in about 15 seconds.
Make changes to the screen until it appears as you want it, click ACCPET when you find the one you like.
