Fossil AM3695 Wrist Watch Logo
Posted on Feb 22, 2012
Dial is not blinking - Fossil AM3695 Wrist Watch
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
442
Points
You have to hold down the top botton for about 15 seconds, then it should blink, it's called demo mode.
Watch face is blinking. Brand new battery. How do I reset?
No matter what I do or however long I hold A the time will not change please help me
How to set date
on the back has a number on the bach in a box. use that number to casio website, maunal archives, use that number. has manual.. hold the top left button when hr blink press again, min, then goes to date use the left side to go up and down the numbers,when you get right number press top left.
How to adjust the time?it is one hour late. Thanks
mcdevito75 here, The mode button should be pressed, note dial blinking, now press set and that particular setting will cahnge, now adjust for the correct time.
Set time on 1440 sports
mcdevito 75 here, You should press the MODE button then, see the display blinking, press set for each function after each function is set press MODE to move onto next function, Hour, Minute etc. Once all set press MODE to stop the blinking and restore normal steady dial.
1helpful
The problem is that i simply dont have the users manual and dont understand how to manipulate my watch
mcdevioto75 here, I'll try to help, 1 of the buttons should say mode, if no button look for a in-dent naer the other buttons and push that in, or press the mode button and see the dial blinking, press set to cahnge and adjust each function, Hour, Minute etc. after each function is set press mode to mave to the next function when done with your functions, press mode to return to a staedy dial.
Jun 21, 2010 • Watches
4helpful
My Casio Gshock GW800D is blinking Blue dial and flashiing "low"
That blinking is to let you know: time to change the battery.
Rate me, please.
7helpful
ADJUSTING ANALOGUE CLOCK
Keep pressing 'select mode' button until you get to H-SET. Than hold 'adjust' button until screen starts to blink. Now you can adjust analog clock by pressing 'start/stop (search)' button. When you are finished, just press 'adjust' button once. That's all.
Battery Life problem
Replaced with new battery if ever the battery 100% new .Then the problem is in the enternal connection is loose connection in the dial that's why intermittent problem.If you have knowledge to repair you can open this and resolder the loose connection,If you dont have the knowledge its better you bring your watch to a service center so it will repair properly and avoid the damaged.
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Jan 10, 2009 • Watches
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
