SOURCE: targus wireless mouse not working
I think my mouse is not moving because one usb is missing. I
have trouble find one usb that can help move my mouse.
SOURCE: HOW TO SET UP AND USE TARGUS WIRELESS COMPUTER MOUSE
I assume this is a wireless mouse, Is there a similar button on the reciever? press this at the same time as pressing the one on your mouse
SOURCE: change batteries in a targus portable mouse
I found the user guide in French. It says to slide back the cover behind the Logo on top.
also found it in English:
Installing the Batteries
Optical Mouse
1 Remove the battery cover from the top of the mouse by
pressing the top center (over the Targus logo) and
sliding it back.
2 Insert the supplied batteries , making sure that the
positive (+) and negative (-) ends of each battery match
the polarity indicators inside the battery housing.
WARNINGS: When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never
combine an alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device.
3 Slide the battery cover back in to position until it “clicks”
firmly into place.
4 Turn on the mouse by sliding the on/off switch on the
bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse,
glows red.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: How do I install the battery on a Targus PAWM004 wireless mouse
yo dude just slide the silver cover back its tight but does come off, instructions available on their website, by the way you dont need a driver for xp will pnp
SOURCE: targus wireless mouse amw05 does not work, I put
The reciever is poorly designed. The green and/or white wires are probably broken on the inside.(pins 2 and 3)
