My friend 9 miles away bought the same phone system. DECT1480 with 4 phones. Usually I can pick up phone things right away, but we are both having the same problems...except her phone buzzes so bad sometimes I have to hang up. There are so many things you do with this system it is confusing. I want to know what to hit to delete new CID numbers.
To select a number, highlight the number and press Menu/select. The phone gives you the following 3 options:
1) Delete Entry Erase the number from the list.
2) Store Into Pb Add the number to the phonebook. The handset prompts you to edit the name and number.
3) Delete All (CID list only) Erase all numbers from the list.
Friends phone:
1) Check batteries
2) Check base unit has good mains connection ! faulty mains extension
SOURCE: cid issues
Are you getting caller ID?
Under phones/sets, you have to tell the system to log the calls.
SOURCE: problem with CID in AT&T EP5632
Your display screen may be powered by the battery in your phone and it might be getting tired. If that isn't the case the LCD display has died. Thanks Jerry
SOURCE: What does New CID=1 mean?
CallerID. CID=1 mean there was one (new) caller ID number recorded by the telephone.
Hope it helps.
SOURCE: CID not working
There are two main types of Caller ID used in the US, most Uniden phones will work with either type, you just need to set it to type "A" or type "B". If you will post your model I will be happy to tell you how to change it or you can call Uniden Customer Service at 800-297-1023
