I have a z740 and it has always taken great pics but recently i have noticed that i can take alot of pics and when i down load them onto my computer with easyshare some of the pics are great then other pics that i took at the same event seem to be clear and yet fuzzy and blurry.1 person in the pic looks great and another person in the pic is fuzzy or blurry then it goes back to pics looks good and then again back to this problem,a friend of mine said it might be the memory card but i have used this memory card recently and all the pics came out great.any suggestions before i spend a fortune having a camera store look at it?
SOURCE: Transferring pictures from computer to camera
Hi Mike. The only way I can think to do this, is with an separate card reader. Then you could take your SD card and load back and forth, from your computer to camera (and vice versa).
hope this helps!
SOURCE: camera starts, then immediately shuts off
I took out the card.
Erased the photos on the built-in memory (after making sure they were copied to my computer.)
Replaced the card.
Voila!
Took some photos and it turned off when I wanted.
I wonder if it will last, or if it is a fluke.
Try it.
[email protected]
SOURCE: uploading pics to mac from SD card in camera
Have you tried using an external card reader?
They look similar to this at Wal-Mart:
http://i.ehow.com/images/GlobalPhoto/Articles/4794433/120257_Full.jpg
I own a mac and always use an external usb card reader to download my pics and it works great. Also, I know that you need to get your pics off first, but you may need to reformat you card at some point so that it will read faster and work quicker in your camera.
For your software issue, have you tried download the software from kodak's website? The program shouldn't cause your apple to crash. I would try re-installing it from there website.
http://www.kodak.com/global/en/service/software/easyshare/en/dln_ekn026079.jhtml?pq-path=4509
SOURCE: Can't format 8 GB SD memory card
The camera doesn't support this memory card.
Memory card support : SD/MMC up to 2 Gigabyte only.
Sorry you will have to downsize.... :)
If helpful pls. rate me and/or recommend me TXS
SOURCE: kodak easyshare Z740 battery problem
I may be able to help with your Kodak EasyShare Z740 that turns itself
off.
Try these steps to fix your camera.
I
hope that helps.
_____________________________________________
Turns Off Fix
Manual Download
I have the same problem, especially at night time. I have tried using all the different settings, with no improvement.
