RCA HD52W56 52" Rear Projection HDTV Logo
Posted on Oct 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sometimes screams a high pitched noise when turned on
We have the above RCA TV. Have had problems with it since Day 1. We returned the first TV for another. This one has had problems also. We replaced the lamp twice in two years. Now the TV sometimes screams a high pitched noise when turned on. It eventually stops after a few minutes. We have Direct TV but that doesn't appear to be the problem. Also, one of the built-in speakers does not come on. We bought and hooked up additional speakers to enhance the sound quality.
Should we just dump it for a new one?
  • tmullins1211 Jan 31, 2009
    I am having the same problem with my tv. It seems to be worse when the wood stove is on, we started putting a fan in front and that helped for a while, thought that it was just overheating, but now it is doing the same thing even though it is cold in here....HELP!!!
Anonymous
Level 3:
Genius:
  • Master 1,605 Answers
  • Posted on Oct 28, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1605
Questions
Helped
746924
Points
3939
The high pitch noise is from the HV. arcing acrss each other.
( the screen comes up at a pop).
I suggest get a better one. ( sorry! no domastic brand).
1helpful
91 S-10 it has a high pitch scream
It sounds like a worn or loose fan belt. It's slipping on the pulleys causing the screeching noise.
Hi i have hust turned my laptop on and it is making a biig noise and it is not stopping it comes on when u turn it on what should i do
Are you getting a high pitch screaming or a grinding noise? The Fan on the heatsink sometimes getting clogged with dust and over time this can cause the computer to turn itself off. Dependant on a high pitch scream this could be a number of problems, memory modules loose or faulty?? Would need more info about the type of sound..
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
2helpful
3answers
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
2answers
High Pitched noise returns after new parts installed.
Use first quality OEM or equiv. transistor, RCA 237470 is
least expensive...............T.
1helpful
4answers
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
High pitch noise..from TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
