SOURCE: Canon IR 210S "Close the Lower Right Door" warning
Yes there is a sensor that most likely got knocked out of place. What you can do is to turn the copier off and disconnect the bottom 2 trays from the main body of the copier and turn it back on and just use the top 2 trays. You can change the trays lay out to what ever size you want, but make sure you change the BLUE DIAL to the correct size you want to use. I belive the sensor is toward the front of the copier right by the edge of the door, it may be knocked out of place or the flag on the door is broken off or one of the door pins are broken and the door is not closing correctly.... Good Luck..
SOURCE: close the front door and second problem is E805
805 is a bad fan usually one of the three on the exit door
SOURCE: e805 error in canon ir 400
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
SOURCE: imageRUNNER 400S Copier: Canon IR 330-400 Ps Ver 1.0 i keep getting the ...
E-100 is an error of the Laser Beam detect PCB. Either the laser unit is not working or the beam detect PCB is not detecting the beam. You can't see the beam so don't try. Since you are also getting a E-220 which is a Scan Lamp error. Most likely cause is a ribbon cable between the CCD unit and Image Processor PCB. You may need a tech to trouble shoot this problem
