Question about Navigon 7100 GPS Navigator GPS Receiver
Computer will not recognize my Navigon 7100?
I connect my Navigon 7100 and it will not recognized and I don't know were to find drivers for it. Any help?
    Problem Solver:
  • 9 Answers
If your useing Windows XP or Vista,drivers arn't needed..Windows "sees" the gps unit as another drive.
If you want to use the logbook , the files are in excel format.
the owners manual shows where the files are stoerd on the memory card!!
Posted on Nov 11, 2008
6ya staff
SOURCE:
My Navigon 7100 no longer speaks the street names after I downloaded the latest software updates.
I had the same problem and this fixed it: Connect the navigon to your computer and go into the files directory and create 3 new empty folders, as follows: (You may want to back up your navigon 1st) After i created these empty folders, I was able to go into settings and turn Stree names on
Create these empty folders within MN6\sound folder.
Celine_67_tts
Isabela_22_tts
Sarah_21_tts
May 13, 2010 | Navigon 7100 GPS Navigator GPS Receiver
Navigon 7100 need activation code key for fresh maps
Activation cord is in the freshmaps activation card that comes with purchas of device.It is on the back of the card remove plastc with nail and you will get 15 digits number in 3block with 5 digits each.
May 05, 2010 | Navigon 7100 GPS Navigator GPS Receiver
I have navigon 7100. Whenever I inputted information it takes a long time to response despite having a signal
That is typical of navigon. Based on Consumer Reports, it is THE slowest GPS to sync and recalculate...on the market.. Up to 5 minutes on some tests....
Nov 27, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Lost password lock on Navigon 7100
forget it if you dont have the unlock code its useless and may even be hot!
Jul 05, 2009 | Navigon 7100 GPS Navigator GPS Receiver
My Navigon 7100 doesn't turn on! It does get charged though...
I had a similar problem with my 2100Max. I took the SD card out, plug it into my computer and then reinstall it. It works like a charm these last months still.
Jun 08, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Connecting computer to navigon 7100
You need usb cable and fresh software. download from navigonusa.com
Mar 09, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Navigon 7100 Fatal Application Error
I had the same problem with my unit.
Did you try to reload ALL the files back to the memory card?
This as a slow process,but it seems to go a little faster if you use a card reader.
Format card using FAT option,not FAT32.
Hope this helps
Jan 21, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Navigon 7100 GPS Navigator GPS Receiver Logo
1,691 people viewed this question
Top Navigon GPS Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Navigon GPS Expert? Answer questions, earn points and help others
