Jazz DV150 Camcorder Logo
Anonymous Posted on Oct 10, 2017
I just got a Jazz DV150 and it wont work right?
It will turn on, then shut right back off when it gets done reading the card. when i plug it into the computer and the computer wont register it's pluged in. it'll only stay on when i dont have the card in, but when i switch it off and on it'll turn back on then say "goodbye" when it's done reading the card.
Tony Parsons
Level 3:
  • Jazz Master 6,405 Answers
  • Posted on Oct 10, 2017
Tony Parsons
Jazz Master
Level 3:
Answers
6405
Questions
Helped
1652340
Points
20272
At least it has the manners to say 'Goodbye'.
4 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jul 13, 2008
SOURCE: ArcSoft Media Converter
I have a feeling its going to have something to do with what Codecs your converter is using. To the best of my knowledge, the DV150 only supports a certain type of AVI. I'm sorry i can't be more help but i'm not really sure.
  • 102366 Answers
  • Posted on Jun 02, 2011
SOURCE: how do you unlock card
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
jcb93
  • 8 Answers
  • Posted on Aug 24, 2011
SOURCE: i lost my manual how to get an manual for my jazz
go to this web link
http://www.meijer.com/assets/product_files/pdf/1000915_GFM-DV150_manual.pdf
Anonymous
  • Posted on Oct 05, 2011
SOURCE: New Jazz DV150. Installed
HI, I just got off the phone with a very nice man in NJ at Digitac. He walked me through a few fixes: Try a different SD card, clear SD card, put SD card in and then start camera, start camera and then put SD card in. None worked, so he said something is wrong with the camera computer and I will have to send the camera in for warranty work.
I have a Jazz dvx40 camcorder, ihad it about a mounth or so and whean i turned it on one day IT HAD THE JAZZ LOGO AND IT DIDN'TURN OFF HOW CAN I FIX IT AND SAVE MONEY???
Worth a try - remove batts and SD card. let it sit for 15 min, then install new batts and the SD card. One never knows what a cold boot can do!
When i have the card in the camera and turn it on it says reading card and it want let me do anything
You need to format the SD card correctly for the JAZZ to read it.
Google SDFormatter and use that - a standard windows format will not work for MOST cameras and video devices.
How do you unlock card on a jazz dv150 camcorder?
New Jazz DV150. Installed new batteries (tested) and SD card (tried switch in both locations). Powers on, says "Read card....", "Goodbye", powers off.
My sd card is lock on my jazz dv151 it wont let me take or rec. anything
there should be a slide on the side of the card to change from lock to unlock.
Nothng is working.
Nevermind I used a different SD card and it worked
1helpful
3answers
I Download music to Mp3 and it says no file on it, but it will play the songs on Windows Media Player.
Try not running the Syn software at all. Try copying the files over manually.
After plugging in the USB cable you should get a small popup that says its connected.
Click on "My computer" and under "Devices with removable storage" you should see a new device called DV.
double click on that and you should see 3 folders. DCIM, EBOOK, and MP3
Copy your mp3 files from your computer into the mp3 folder of the camera and it should work.
Mp3
Top Jazz Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Jazz Video Camera Expert? Answer questions, earn points and help others
