The microwave seems to be working properly for 10-15 seconds and then has a power failure. The timer display blanks out and then comes back on in a few seconds. I can then start the microwave again, but it will only run for another 10-15 seconds or so before quitting again. When I run the microwave with the surface light on, the light remains on the entire time, so I know the house hold circuit is not shorting out.
SOURCE: kenmore over the range microwave oven
hi how r u
i want to know what's the average power that i should put it on my microwave
thank u
SOURCE: Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then
stops and shows "F-9", it is the magnetron that has failed. The fact
that the unit starts and runs with the TICKING SOUND means the control
board is sending signal to inverter board and the inverter board is
sending signal to magnetron. Magnetron is covered by full 5 year
warranty, inverter board is only 3 years.
SOURCE: microwave starts and then half
model hotpoint counter saver plus power failure warning starts then cuts off
[email protected]
SOURCE: kenmore microwave model 665.61629100
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
SOURCE: Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed...
POWER FAILURE &FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 —Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 —Microwave Relay Failure: Check the microwave relay.
F7 —Microcomputer Board Failure: Change the microcomputer board.
