Hello
Try these links.
esupport.sony.com/US/perl/model-find.pl?mdl=DCR-SX65/L
http://www.dataentryjobs.us/67948.html
www.abt.com/documents/.../DCRSX45S_handbook.pdf - United States
www.manualowl.com/p/Sony/DCR-SX65/Manual/107609Cached
www.retrevo.com
SOURCE: sony camcorder dcr-1p7e
Here is the only solution:
CODE C:31:22 Symptom/State T reel fault
CODE C:31:22 Symptom/State S reel fault
Correction: Load the tape again, and perform operations from the beginning.
Trying
different brands of DV stock does not solve your problem. If this
problem continues you could have a tension problem. Replacement of the
S & T reel tables will solve your problem.
SOURCE: DCR TVR18E Sony
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of
your hand. Eject the tape and reinsert. You may need to do this a
couple of times.
SOURCE: Sony Handycam DCR-PC109E User manual
I moved every moveable object on the handycam to no avail and then I wiped the screen to clean it and got the menu. It is a touch screen cam. Thanks antway.Ian
SOURCE: Sony Handycam DCR-TRV460 Digital-8
Camera has dirty / clogged video head.
Use good quality video head cleaning cassette.
SOURCE: blinking error code C:21:00 how to remove from sony camcorder
Try depressing the small "Reset" button with the camera power on. Use a sharp pencil/ball point pen to do that. It resets the logic in the camera and may help.
