SOURCE: toshiba 36zt29b television
Hi, I am an idependant service engineer, who is currently looking at one of these actually a 36 inch 36zt29b. So far, it looks likely the digital board is at fault sending an 'off' signal to the digital power board. The digital board itself is no longer available. I am going to have a look at this board, and try to fault find it. If I have any success I will post again.
SOURCE: Toshiba 62hm95 BUS line,. what is a BUS line and how do I fix it?
allmansfan your problem could be a cable that needs to be reseated if you take back off first unplug it there is a DVI cable with screws unscrew it pul the cable off and blow it out with some air reseat the cable put it back together and yo should be good to go
amjr2003 take the lamp out and look at it you will be able to tell if it is bad blown,discoloration,bulges in the globe etc. if not you may have a lamp door switch that need s to be aligned look at it there is a screw work the switch around where it lines up with the post
SOURCE: Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
SOURCE: Color separates and picture bows on 9 year old RCA big screen.
Hi, This is a convergence problem and you can set it right by changing the STKs. It is a professional job and i have knowledge of people who ruined their tv by spoiling some miniature surface mounted components close by. You may need to look at pico fuses too. I would say seeek professional help if you not comfortable working with electronics. Check out at www.fixurtvs.com,
SOURCE: I have a Toshiba 56HM66 DLP projection tv. The
My tv has the same exact problem have you figured out what it is ??
