Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
My washer will not start
I tried to hold the Controls Lock/Unlock for 3 seconds. Nothing happens and there is a problem code of F 01. I tried unplugging etc. Any suggestions?
  • 958 Answers
F-01 stands for a CCU problem.
if it is still under warranty, don't touch it. if it is no longer under warranty, then open the unit, check for cables that are loose in connections, pull them out and inspect every plug of the ccu. that is the control unit.
test it again.
if F-01 would appear again, then you have to replace the CCU board.
tnx 4 using fixya,
drcool
Posted on Oct 27, 2008
6ya staff
SOURCE:
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
The code cl keeps coming up and the washer will not shut off
CL is child lock. Press and hold the child lock button(maybe a key icon) for three seconds to unlock
Mar 23, 2015 | LG WM2455 Front Load Washer
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
Jun 28, 2011 | General Electric WCVH6800J Front Load...
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Controls locked on washer and cant unlock them
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Mar 15, 2010 | Maytag Washing Machines
My washingmacine stopped working completely. it started with one cycle going out , then a week later another cycle stopped working. now none work. when i turn the machine on i can here a hum , but nothing...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.))))
Feb 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool duet red light keeps blinking and wont start. it is not locked.I tried unplugging it and nothing works.
Nov 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
lit, all buttons are disabled. You can lock the washer while it is
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Jun 17, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
