The message you are seeing on your WMF Presto coffee machine suggests that it is stuck in the boot process and is unable to start up properly. This could be caused by a software or hardware issue.
Here are some steps you can try to troubleshoot the issue:
- Check the power supply: Make sure that the machine is properly plugged into an electrical outlet and that the outlet is functioning correctly. If the outlet is not working, try plugging the machine into a different outlet.
- Restart the machine: Try turning the machine off and on again to see if it resolves the issue. If this doesn't work, try unplugging the machine from the power source, wait for a few seconds, and then plug it back in.
- Check the USB port: The message you are seeing on the screen suggests that the machine is looking for a USB device. Check to make sure that there is no USB device plugged into the machine. If there is, remove it and try restarting the machine.
- Contact the manufacturer: If none of these steps work, it may be a hardware issue. Contact the manufacturer or a qualified technician to diagnose and fix the issue.
It's important to note that attempting to fix the machine yourself may void the warranty or cause further damage.
