Ip camera continued
Ready
  • 1,879 Answers
Gimme a sec - getting resource for screen share
Posted on Oct 26, 2008
  • monk3ybidzness
    monk3ybidzness Oct 26, 2008
    go to this link (it's from Citrix)
    https://www.fastsupport.com/627046563
6ya staff
SOURCE:
Cannot connect to network. It show IP address 0.0.0.0
contact your service provide for assistance on how to set it up
Apr 28, 2015 | HP LaserJet P2015n Printer
Ip address?
Switch power off. Make sure the network connector is connected to the printer, now, hold the green(go/print) button whilst powering the printer up continue to hold the green button until the display has lit, wait until printer is ready and it will now print out the configuration page which has the Ip ranges listed
Jul 22, 2014 | HP LaserJet CP1215 Color Printer
Turn on shuts off blue screen B8000028
The steps to resolve this issue on a product that you want to set up with a wireless connection and on a product that you want to set up with a wired, or Ethernet, connection differ slightly. Depending on the connection type you want to set up, select one of the following methods, and then follow the steps provided to resolve the issue.Method one: Resolve the error on a product that uses a wireless connectionStep one: Print a network configuration page
  1. Disconnect the power cord from the back of the product.
  2. Remove the phone or Internet cable that is connected to the back of the wireless router. Do not reconnect this cable until instructed to do so.
  3. Reconnect the power cord to the back of the product. If the product does not turn on automatically, press the On button (c00636182.gif ) to turn the product on.
  4. Make sure that the blue Wireless light is on. If the Wireless light is not on, press theWireless button on the front panel of the product to turn wireless on.
  5. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
  6. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
  7. Press the Setup button (c01726396.gif ) on the product control panel, select Network , and then select Wireless Setup Wizard . Follow the instructions in the wizard to complete the configuration.
  8. When the Wireless Setup Wizard is complete, press and hold the Cancel button for several seconds. The network configuration page prints.
  1. Make sure that the computer is connected to the same router that the product is connected to.
  2. On the network configuration page that you printed in 'Step one: Print a network configuration page,' look in the General Information section. Make a note of the following information.
    • IP Address
    • Subnet Mask
    • Default Gateway
    note.pngNOTE:Each of these addresses is in the IP address format. For example, 192.168.1.100 is an IP address. Make sure that you note the numbers and the dots exactly as they appear on the network configuration page.
  3. Open a Web browser, such as Internet Explorer or Mozilla Firefox, on your computer.
  4. Type the product IP address in the address bar of the Web browser, and then pressEnter . The Embedded Web Server (EWS) page for the product opens.
  5. On the EWS page, click the Networking tab.
  6. In the left pane of the Networking screen, select Wireless (802.11) , and then select theIPv4 Configuration tab in the right pane.
  7. Select Manual IP .
  8. In the IP Address text box, type an IP address that is within the range of 192.168.1.10 to 192.168.1.60. For example, the IP address 192.168.1.25 is correct, but 192.168.1.61 is incorrect.
  9. In the Subnet Mask text box, type the Subnet Mask address that you located on the network configuration page.
  10. In the Default Gateway text box, type the Default Gateway address that you located on the network configuration page.
  11. Click Apply to save these settings.note.pngNOTE:After the new IP address is set in the EWS, the computer loses the connection with the product, and the EWS page becomes unresponsive. This is expected behavior. Wait 10 seconds, and then continue with the next step.
  12. Close the Web browser.
Step three: Restart communication and complete the installation
  1. Press the press and hold the Cancel button for several seconds. The network configuration page prints.
  2. Make sure that the product is connected to the network and that the IP address matches the IP address that you typed in 'Step two: Set the product IP information in the Embedded Web Server (EWS).'
  3. Connect the phone or Internet cable to the back of the router.
  4. Continue the product installation. If the software has already been installed, insert the software CD into the computer CD drive, and then select Add A Device from the menu that appears on the computer.
If the installation is successful and the error message does not appear again, the issue is resolved, and there is no need to continue troubleshooting.If the installation is not successful and the error message appears on the product control panel, continue with the steps in the Workaround section.Method two: Resolve the error on a product that uses a wired (Ethernet) connectionStep one: Print a network configuration page
  4. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
  5. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
  6. Make sure that the network cable, or LAN cable, is connected to the computer and to the product.
  7. When the product is connected to the network, press and hold the Cancel button for several seconds. The network configuration page prints.
    • IP Address
    • Subnet Mask
    • Default Gateway
  6. In the left pane of the Networking screen, select Wired (802.3) , and then select the IPv4 Configuration tab in the right pane.
  1. Press and hold the Cancel button for several seconds. The network configuration page prints.
Or else remove CMOS battery located on formatter, wait 15mts refix then check..
Oct 06, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Want to reset assigned Ip address on a dell 1720dn printer
When the Ready/Data light ready_light_icon_0.jpg is solid, press the Continue button continue_button_0.jpg to print a menu settings page and a network setup page.
Select TCP/IP heading on the network setup page.
There you can change your IP address.
Aug 10, 2011 | Dell 1720dn Laser Printer
When networking, I can see the printer on the network, but when I send a test page, the printer immediately says "cancelling". I cannot figure what the problem is. Any suggestions?
There must be IP address conflict.
Check the Dell printer IP address
Open Printers and Faxes Folder
Right click on printer icon ( dell )
Click on Properties
Under Ports Tab check the IP address with check mark
If the Ports IP address is Different as that in Dell Printer
Highlight the Port with IP address and click on Configure IP below
Change the IP address to the Printer and Click OK
Also check if there are print job stuck in the Queue ( like no. 1,2 )
The printer icon should show READY and 0
Or Else, Right click on the printer icon and Click Cancel Print job.
Restart your PC and Printer and try to print. It should work
If this does not work, let me know what is the Operating system of your PC
Try this Step if your Operating system is Windows 7
Left click on Troubleshoot
Continue with the Wizard and complete it
You are ready to print.
Nov 02, 2010 | Dell 3000cn Laser Printer
Configure tcp ip hp 750c
Assuming the JetDirect card is installed and properly functioning, use the following. Also, you may have to update the rom on the I/O Card to the latest version.
  1. From the front control panel message, Ready or Ready to Plot, press ENTER.
  2. Press the Up arrow key until I/O Setup appears, and then press ENTER.
  3. Press the Up arrow key until Modular appears, and then press ENTER.
  4. From the front control panel message, Cfg Network=No, press ENTER.
  5. Press the Up arrow key to change to Yes, and then press ENTER.
  6. Using the Arrow keys, scroll to Cfg TCP/IP=No appears, and then press ENTER.
  7. Scroll to Yes, and press ENTER.
  8. Press the Up arrow key until BootP=Yes appears, and press ENTER.
  9. Press the Up arrow key to change to No. Press ENTER (When using BootP or DHCP, keep the setting BOOTP = YES *. The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect. No other TCP/IP configuring is necessary.
  10. Press the UP arrow once to get to the IP byte section.
  11. To change the IP byte, proceed as follows:
    1. Press ENTER.
    2. Press the Up or Down arrow key to change the number.
    3. Press ENTER.
    4. Press the Up key to continue to IP Byte2=xxx.
    5. Press ENTER.
  12. Configure the remaining bytes of the IP address in the same manner. A valid IP address is required for proper operation.
  13. Configure the subnet mask bytes (SM), syslog server IP address (LG), default gateway (GW), and timeout (TIMEOUT) by pressing the ENTER and the Up or Down arrows in the same manner as above. The timeout parameter default is 90 seconds. Up to 3,600 seconds can be configured. If set to zero, the timeout feature of the HP Jetdirect print server is disabled; TCP/IP connections will remain open until closed by the server.
  14. Press PREVIOUS repeatedly, until the Ready to Plot or Ready message appears. Refer to the HP Jetdirect Network Interface Configuration Guide to configure the network operating system.
  15. Press the Up and Down arrow keys simultaneously to save the IP address on a 750/755 plotter. (A page should print and the IP addresses will be saved.)
Nov 19, 2008 | HP Jetdirect J2552A/B (J2552AB) Print...
I followed this suggestion and now the IP address is 0.0.0.0. I can not get to the printer setting. I don't know if the DHCP setting still remained as static instead of dynamic. ANY SUGGESTION?
I had the same problem, after removing the DHCP settings, maybe for an error during the configuration the printer didn't assume the new IP address and it resulted 0.0.0.0 from the configuration page.
No way to connect to the printer until I did a network card reset following this procedure:
7. Network Card Reset:
a. Turn the printer off.
b. Open the front cover.
c. Hold down the Continue and the Cancel button while powering the printer on.
d. Release the buttons when the Error light (bottom light) stays on solid.
e. Close the front cover and the printer should return to a READY state.
f. Press and release the continue button to print a network settings page.
g. On the page that prints verify the following:
�� Status = Not Connected
�� Active = Yes
�� DHCP,BOOTP,RARP Enabled = Yes, Yes, Yes
�� Address Source = Manual
�� Address = 0.0.0.0
The printer took a new IP address from the DHCP server.
Since my goal was to set a fixed IP address, I entered the printer configuration through Internet explorer, typing the newly assumed IP address and going to TCP/IP settings where I removed The 'Auto DHCP' and I set the IP address I wanted.
Oct 20, 2008 | Dell 1710n Laser Printer
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Slow response time
Before a digital camera is ready to take a picture, the electronics inside the camera must get ready to capture the picture and save it to the memory card or the internal camera memory. Press the shutter button half-way (to its first detent) to set the exposure and focus. When the ready light is green, continue pressing the shutter button completely down to take the picture. The picture is taken almost immediately.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Open Questions:
Computers & Internet Logo
Ekse
Marvin
Marvin
