I conected the dsi action replay to my pc with the ubs cable it comes with and it overheated!!!
SOURCE: action replay code manager doesnt see the action replay
Many are experiencing this, what you are looking at here is a faulty action replay. go to the Datel website and submit your serial number to them, it will immediatly say whether or not your AR is from the time period when they had a problem with the internal USB reading system, if it is, then send it in and one will be shipped withing 10-12 weeks
SOURCE: my action replay code manager is empty and I want to add pokemon
Heres your problem, I believe you just recently purchased this AR, the new version of action replay require a software update found on Datel's website, after downloading this software your Domain Suffix of your Optical Drive will automatically replace the program with the newer one. Open up your winsock processor and buffer the Native file of your AR back into your fluxus core before adding codes to your action replay, if this does not fix the problem, submit a complaint to the Datel Hacking Team located at PO box 45265 North Ridge, CA. This whole process should take anywhere from 10-12 weeks to fully resolve
SOURCE: My DS action replay is broken
If you hold A B START AND SELECT at the same time, with the power OFF, then turn it on with your thumb or something and let go when it says the product isnt endorsed with nintendo. hope it works good luck =)
SOURCE: Action Replay Disc Problem!! HELP ME I AM DESPRATE!!
This just happend to me 5 minutes ago..If you have a laptop with a cd thing on its side then you may not beable to use the Action replay cd with your laptop, but you can use a DESKTOP computers cd slot ,(the one that comes out and you put the cd on ) but if you Realy want to use it on you laptop then i recomend you use a Desktop computer and with a disc copy software copy the AR cd onto a normal sized CD and then perfecto u are done
SOURCE: I just got a dsi action replay. I installed the
The computer depending on the model can search the disk and find it. I had the problem with my vista and the disk had the driver.
