Uniden BC350C Base Scanner Logo
Anonymous Posted on Oct 26, 2008
Need instruction manual for uniden bearcat BC350A
Can't program without it [email protected]
  • smith65ron Mar 31, 2009
    need instruction manual for bearcat bc350a.
  • Anonymous Apr 13, 2009
    need instruction manual for uniden bearcat BC350A
Mechanic688
Level 2:
  • Expert 204 Answers
  • Posted on Nov 01, 2008
Mechanic688
Expert
Level 2:
Answers
204
Questions
Helped
140384
Points
542
Hello, Don't know if your wanting one for a 350 A or a 350C so I'll guide you to both places. For the 350 A go here and download. http://www.uniden.com/pdf/BC350Aom.pdf
For the 350 C go here, http://www.uniden.com/pdf/BC350Com.pdf
Hope this helps you out,, Let me know,,,,,,,, Mechanic
Testimonial: "didn'know that. mutch thanks Don"
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7205
Points
How do block certain frequency
Testimonial: "good to know . thanks again. Don"
Uniden Bearcat BC350A Scanner. How do I get the memory loss off it.
Question edited to add FULL make model (what it is) as needed on Fixya.
Memory Loss. - Uniden BC350A Support Question - HelpOwl ...
https://www.helpowl.com > BC350A > Technical-Support
Feb. 29, 2016 - Memory loss occurs if the the scanner is left for a long period of time without power. Please note that in case of memory loss to the scanner ...
BC350A Memory Loss - Uniden - HelpOwl.com
https://www.helpowl.com > Uniden > BC350A > Research
Our system has returned the following pages from the Uniden BC350A data we have on file. ... Avoid a location that could cause scanner memory loss.
Helpful Hints - Uniden BC350A User Manual - ManualsLib
https://www.manualslib.com > ... > User manual
memory loss. If memory is lost, simply reprogram each channel. The display shows "MEMO LOSS" when memory is lost. Always press each keypad button firmly ...
How do i program my scanner to hear local police? i have a uniden bearcat bc350a
Depending on where you are your local police may be using encryption technology that will only let you hear beeps and tones without a proper decoder device.
2helpful
I need a instruction manual for me old undien bearcat BC350A
You can download and print your scanner manual here:
http://uniden.com/pdf/BC350Aom.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
4helpful
2answers
Hello, i need an instruction manual for a bearcat bc350a. thank you brad
If this response helps, please take a moment to post a rating. "Very Helpful" would be appreciated.
1helpful
I need to know how to program my uniden bearcat BC350A scanner. I need to redo the codes in it and I forgot how to replace the codes that are already programmed in.
You can follow the link below to download/print the manual for your BC350A, and it will walk you through the programming steps.
For a comprehensive database of active frequencies in your area, visit:
Bill B
3helpful
How to program
There are several ways to program your scanner, so it's best that you refer to the owner's manual for detailed instructions. You can download/view/print the manual at:
How to set codes and lock them
Here is a link to the pdf format manual for this particular scanner:
Go to page 14. That is where the instructions begin for programing frequencies. For the program lock feature, go to page 17.
I would have pasted the instructions here, but there are illustrations that will not copy and past to here.
Dean
Rollin CBs
1helpful
Scanner
Hi if you use this link it is the full users manual for the 350a everything you want to know is in it
How to program my uniden bearcat BC350A scaner.
Here is a link to the owners manual for this scanner:
page 14 begins the procedure for programing the frequencies.
Dean
Rollin CBs
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
