Vacuums Logo
Peter Ash Posted on Feb 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cable will not retract
Model: King, Type: Home
VacuumSpot
Level 2:
Novelist:
  • Expert 171 Answers
  • Posted on Jul 23, 2013
VacuumSpot
Expert
Level 2:
Novelist:
Answers
171
Questions
0
Helped
79997
Points
286
If you are having problems with a NIlfisk King cord reel it will either be that the cord is simply dislodged or the retract could be faulty. I have made a video showing how to pull it apart which could be used as a reference to diagnose the issue.
If you need a new retract we have these available online as well, the part number is 22352606 Nilfisk King Cord Rewind
1helpful
Sebo Airbelt K1 Komfort 2100w power cable will not retract
Changed Category from Refrigerators to Sebo K1.
Sometimes these appliances have hidden screws, sometimes they have hidden plastic catches and need a 'spudger'. I would think the cord retraction mechanism and spring is a large component so would need a full disassembly. I haven't seen the video in the link, but if he is getting as far as replacing a motor, he is fully disassembling. The normal way to fix a binding cable retract is put extend the cable all the way and start again.
https://www.google.com/search?q=sebo+airbelt+k1+komfort+disassembly
Our retractable cord is stuck. How do I fix this problem?
Hello, Elizabeth -
You may find the instructions here helpful in getting the cord to retract again:
https://www.hunker.com/13408865/how-to-repair-a-cord-rewind-in-a-vacuum-cleaner
This is a link to other instructions:
https://www.doityourself.com/stry/fixing-the-cord-reel-on-a-canister-vacuum
If you wish to post the make and mode of your vacuum cleaner, I or another volunteer Fixya answerer may be able to find repair instructions specifically for your model of vacuum cleaner. You can choose Comment and type the make and model in the Comment box.
Best wishes.
Jan 13, 2019 • Vacuums
1helpful
Retracting spring is either broken or not in correct position to work.
Sep 26, 2016 • Vacuums
1helpful
Electric cable won't retract
try this link it's not the same model but it may help you on hoe to get to the cable sounds like the spring as broke or come adrift
http://www.sannerud.com/house/miele.html
Aug 21, 2012 • Vacuums
Cable not retracting
Hi Peter,
I'm sorry to hear your DC05's cable is not retracting. I'd encourage you to give our UK Helpline a call on 0800 298 0298, as we'd appreciate the opportunity to provide further assistance. Our Helpline is available from 7am until 10pm, 7 days a week - please have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
12helpful
Nilfisk king 540: The cable is stuck. I can´t take it out
Tools required: Haxalobular screwdriver (Torx or 'Star'), Strong hands/fingers, flathead screwdriver.
Possible hazards: sharp edges (metal plastic), bacteria enriched dust/dirt.
Notice the black ring/skirt near the bottom of the unit...sit on the vacuum cleaner, and pull very firmly at the ring, which will begin to click and pull upwards, rotate around the unit pulling the ring up until the whole ring comes off and you can pull it off over the top of the unit.
Now, there will be a white plastic ring revealed around the unit, using a Flat Head screwdriver to pry the ring out of the grooves it sits in (pull it off towards the bottom of the unit as opposed to the intial black ring coming off upwards).
Now take the handle of the unit and give a firm **** upwards, the whole encasement will slide off in your hand.
You will now see the spring loaded cord retracter. The problem here is that the spring has become too losely wound back onto the larger spindle, or it is dirty.
Firstly pull the entire power cord through the outer shell that you removed (you will need to unscrew and remove the black facade that the cord goes through otherwise the head of the cord wont go through).
Then take the plastic cirlce cover off the smaller spindle (carefully as the wound tin spring could pounce).
Now you need to manually turn the larger wheel clockwise until it has no coil left on it, and the smaller coil now is full.
While winding, dont let the powercord wind back onto the wheel, let it sit to the side (there will be a bit of tangle which will go back to normal when we finish winding back the other way).
Once it is fully loaded onto the smaller coil, wind it back on to the larger coil again, but make sure it's loading on 'tight'. You can ensure this by keeping some pressure on the smaller spindle while winding (be carefull because the coil edge is sharp). Once the smaller coil is basically gone and there is just a small curved end of the coil, put the small spindle back on making the curved coil wrap around it.
Wind some coil back onto the smaller spindle so there is atleast one full ring plus a small overlap, around the spindle, or it may come off. Also, make sure that where the cord is coming out of the larger spindle, is pointing towards where it goes out the back of the vacuum cleaner, so that when you pull the cable it wont wind the wheel at all, otherwise it may wind some coil off the smaller spindle.
Proceed to put the unit back together, but before putting the white and black rings back on, test the retract button. I noticed the first attempt to put it back together that the external button had not lined up with the internal mechanism and it wouldnt retract, i had to open it again.
All done, it should now retract, but it will never be as strong as the day you bought it, but atleast you dont have to have the cord hanging round. Hope this helps.
May 18, 2009 • Vacuums
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 • Vacuums
1helpful
Porter Cable Roofing nailer rn175a
Replace the O Rings and the trigger valve assembly. 9/10 sticking rods on the Porter Cable guns is caused by a faulty TVA.
Nov 08, 2007 • Vacuums
Top Nilfisk Vacuums Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
