Number following "E" Cause How to correct 2 No paper. / If paper is not installed, load it
and then press the <Black> or <Color> button. When paper is
installed, check each of the following items and try printing again. 1. Confirm only recommended paper is installed. 3 Paper jam Remove the jammed paper. 1. Confirm there is no foreign material inside the machine. 4 Empty ink tank An ink cartridge is empty. 5 The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized. The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed. Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. 7 The ink cartridge is not installed in the appropriate position. The ink cartridge is not installed in the proper position. 8 The waste ink absorber is almost full. The waste ink absorber is getting full. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations. 9 A specified period of time has
elapsed without receiving a response from the digital camera. / A print
mode compliant with PictBridge is not selected. / A specified period of
time has elapsed without receiving a response from the digital camera. The machine cannot communicate with the connected camera. 1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. 1 , 4 The ink cartridge cannot be recognized. An unsupported ink cartridge may be installed. 1, 6 The ink level cannot be correctly detected. A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error
and continue printing without replacing the ink cartridge. However, the
remaining ink amount cannot be detected properly, so the function to
detect the remaining ink amount does not operate. 1 , 9 Scanning failed. Scanning a document failed. 2 , x (Where x represents a number) - Turn the machine off, and remove the power cord from the electrical outlet.
Paper does not feed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
If paper jams frequently occur, check the following:
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
Install a recommended ink cartridge.
If one of the ink cartridges is missing, this error can occur.
Install each ink cartridge in the proper position.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing
can continue until the waste ink absorber becomes full. If the waste
ink absorber becomes full, the machine will require service.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
If the camera does not support either one, the machine cannot print directly from the camera.
2.
Set the camera in PictBridge print mode before it is connected to the
machine. This is required before printing for some cameras that support
PictBridge.
Please refer to the camera instructions for more
information about procedures required before and after connection to the
machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 5
Install only recommended ink cartridges.
Replace the ink cartridge.
Check if the document is placed in the correct orientation / position and try the operation again.
3 , x
4 , x
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
