If your 1/2" gas pipe is at the location, it should be stubbed out with a shutoff valve. the valve could be a 1/2" female pipe thread that your gas flex line will attach to-the flex line should have an adapter to fit the 1/2" female pipe thread, if the valve ia flare fitting the adapter is not used. use thread compound on the pipe threads,not teflon tape when working with gas, but nothing is required on a flare fitting.
