I've changed the hose and screens that connect home water to Kenmore washer. How should I troubleshoot and repair. Problem is with cold water line only. Barely a trickle cold, while plenty of hot water. Cold water valve on all the way and water flows into hose. Problem in machine.
Probable but unlikely
the control valve for the water ( hot or cold ) has a diaphragm in the main flow with a small hole in it to act like a pressure regulator
so when the solenoid shuts off the water , water flows through that small hole and locks the diaphragm firmly on the seat
I suggest that the low flow is because that diaphragm has been compromised and is not opening correctly for full water flow
take it apart and clean it out or replace it
SOURCE: Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
SOURCE: Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
SOURCE: kenmore 70 series want fill with cold water
You may have gotten some sediment in the water inlet valve which is clogging or restricting the cold water solenoid. If you live in an area that has hard water, or if you use well water, this is common problem. The valve has electric solenoids controlling the water flow and sediment screens. One for hot, and one for cold. If you turn off the water supply and remove the hoses from the back of the washer, you can see the sediment screens on the valve. You try cleaning them while the valve is installed to see if this will correct some of your flow problem. Also, check the fill hoses. Some hoses have restrictor screens in them which can also become clogged.
If that doesn't work, you may also attempt to clean the valve by removing it and placing it in a 50/50 solution of distilled vinegar and water. Allow it to soak for about a 30 minutes. Mix a solution in a container and submerge the valve portion only, leaving the electrical contacts dry. After 30 minutes flush with warm water. Sometimes this works, sometimes the valve needs replaced. You may want to replace the valve altogether if you're going to go the route of removing the it. This will eliminate the guess work and save yourself from having to repeat these steps twice. The following link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
Replacements can be purchased on line at appliancepartspros.com, searspartsdirect.com, repairclinic.com, or pcappliancerepair.com. All these sites offer great service with competitive pricing, so shop around for the best price.
