Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
funnel head Posted on Aug 17, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Chirping noise and flashing front power light.
I hear a chirping noise and the front power light flashes in sequence to it when turning on the TV, and TV will not work. When peaking behind TV through holes in the back, one green light (on circuit board) stays green and another flashes to the chirping, too. this occurs at 1 second intervals. Hitachi model 43FDX10B.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
477
Points
I had the same problem with my 46" Hitachi TV. We left it unpluged for a couple of days (literature says at least 4 hours) Pluged it back in, held in on the AVX and power button at the same time, this puts it into self diagnostic mode. Error codes should appear on the TV screen, then it should instruct you to hit any key to continue. Press the AVX button and it should put your TV back to normal. I suggest however, that you download the specific manual off the internet for your TV. I got my manual from an electronic forum site (http://www.eserviceinfo.com). My TV model is Hitachi 46EX3B. Hope this helps.
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on Aug 17, 2006
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1649741
Points
8439
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 26, 2006
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
318
Points
Hey techman - when you say shorted do you mean shorted in the IC or where the ic solders to the board?
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
4answers
Hitachi 53UDX10B power button flashes, chirping noise, LEDs flash
The convergence issue might not affect the TV to the point of not turning ON.
The chirping noise you hear, it means there is a short circuit in the circuitry, possible the HOT or power supply assembly.
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
1helpful
2answers
TV makes chirping noise.
Power Lite LED indicator on the front panel bazel flashes?Ur power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
2helpful
Lamp light flashing on toshiba 50" projection tv
TV tries to come on - yellow light next to power light flashes but then it turn itslef off.........It tries agin after few sceonds and sequence repeats. I can hear the sound but no video
6helpful
2answers
TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
2answers
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
