Reset samsung clx-3170
The drum fills up with waste toner and you can empty it but its messy and you need to clean everything carefully after taking it apart. Take out the imaging unit, unloosen the screws on both sides, unmount the retainer springs and push the center pin out of the drum. Take out the drum and unscrew the two screws that were hidden behind the drum. Now take away all parts so that you can empty the waste drum container. Clean everything especially the light emitting panel, drum and white plastic cover needs to be clean. Hope this helps.
SOURCE: Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
SOURCE: Imaging Unit needs to be Replaced
No, what actually happens is the drum fills up with waste toner and you cannot empty it.
SOURCE: Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
SOURCE: setup samsung clx 3170 on shared network
yes
if u use wireless printer u receive n send document via that printer.
SOURCE: I have a Samsung CLX-3170.
I looked up clx-3170 and couldn't find it on the Samsung website.
